Results 1 to 10 of 15
Thread: Speaker Advice
    Feb 2011
    Default Speaker Advice
    So I've been reading thread after thread about which speakers to use. I think all I've done was add more options and make the decision actually tougher. Some of the threads are a bit dated as well. So I wanted to ask now, what would you suggest I buy? The Polks seem to get a ton of love here and in general. I listen to mostly hip hop, but am not trying to win any sound competitions. If I'm looking in the $150-$250 range for the front and rear door speakers, should I go with the Polks?
    Jan 2015
    North East, MD
    The factory radio/speakers are 2 ohm units, preferably you'd want to stay with those. 4 ohm will work but it will cut down your volume some.
    Matt Jones
    Feb 2011
    OK thanks. 4 ohm wont be a problem with an amp, correct?
    Cambridge, MA
    Jan 2015
    North East, MD
    Quote Originally Posted by ejm41 View Post
    No, 4 ohms is the standard usually for car systems, it's when you go lower you need to make sure the amp can handle it.
    Matt Jones
    Feb 2011
    Quote Originally Posted by Executor999 View Post
    Thanks! Saw the second 2 but somehow missed the first.
    Nov 2009
    I'm using THESE. I have no complaints about them. They're 2 ohm and I'm not running an amp. Just replaced the factory door speakers with these. There's no distortion whatsoever and they really scream at higher volume.
    Terry Scott
    Feb 2011
    Quote Originally Posted by terryscott621 View Post
    I have those as potential options too! Did you use these in all 4 doors or did you put components up front?
    Nov 2009
    I used them in all four doors.
    Terry Scott
    If you want speakers to fit within the factory mounts with the water deflectors (there's a lot of water POURING into the doors), you'll need to go with a speaker with less than a 133mm or 5.25" cutout. If you were looking for a higher end (more expensive) true to 6.5” size speakers, there's not many,, actually hardly any that will fit the stock mount. However, there are a number of popular so called 6.5” speakers that will work within or close to your budget, like the Polk Audio MMs and Dbs, JL Audio C3-600, and the Infinity Kappa 60.11cs and JBL P660c speakers - to name a few. As said you can run 4-ohm speakers in place of the stock 2-ohm speakers and they'll work fine, just be sure you go with a speaker with a cutout diameter less than 133mm/5.25" for a "bolt in".
