Results 1 to 4 of 4
Thread: Suspension Upgrades
    Jan 2015
    Des Moines, IA
    Default Suspension Upgrades
    So I'm looking at stiffening up the rear of the car for traction purposes. It sounds like I want all of the following...
    -Rear LCA's
    -Rear Trailing Arms
    -Rear Toe Rods
    -Differential Bushings
    -Cradle Bushings
    -Upper Control Arm Bushings
    I can basically get all of this from BMR but they don't offer a non-adjustable rear LCA in stock size. So would I be better off getting the adjustable ones and setting them up like stock, or just lower the car on something like eibachs? I'm still on stock struts. Is lowering the car going to screw up my 60ft's?
    A lot of guys run their cars with stock metal but new bushings and don't have an issue. Are you planning on racing the car all the time? If so, then replace all of it, but IMO, I'd replace bushings and the trailing arms with the non adjustable ones and call it good.
    Jan 2015
    Des Moines, IA
    No road racing or autox but drag racing will happen.
    My car ran low 11's with all poly in back and new trailing arms, but otherwise is stock. Just depends on what you want to spend your money/time on.
