Page 1 of 6 123 ... LastLast
Results 1 to 10 of 56
Thread: How Restrictive are the stock Mufflers? This much.....
    Friendswood, TX
    Default How Restrictive are the stock Mufflers? This much.....
    Did a little work to the car this past week.
    a) Strapped it to a local dyno for baseline then again after the work.
    b) Kid there had the "brilliant idea" of pulling off the mufflers to get another dyno run comparison point
    c) Holy cow - the stock mufflers are massively restrictive!
    ARH Long Tubes 1 7/8" / Magnaflow Mid Muffler / Cherry Bomb Vortex Mufflers / Magnuson Supercharger 1.9 / Ported blower base / 2.8" Pulley / LS3 rockers with Trunion upgrade / Trick Flow LS3 cylinder heads / Overdrive "non-cog" pulley system / 8-Rib Pulley system / ATI Super Damper / DOD Delete / Lunati Lifters / Custom Patrick G Cam Grind / Wiseco Forged Pistons / Injector Dynamics 85lbs / 4" RotoFab Intake Tube / 90mm MAF Tube / VMax 90mm Ported Throttle Body / LS7 MAF Card / ZL1 Fuel Pump / JMS Fuel Pump Booster / VaporWorx Controller / B&M Tranny Cooler with fan / Circle-D Heavy Duty Rebuild & 265mm triple Disc Billet Converter / Camaro Tranny Pan / Custom Engine & Tranny Tune by Patrick G / Eibach Lowering Springs / BMR Front & Rear Sway Bars & LCA's / Moog Front Control Arms / DBA 4000xs Rotors / Hawks Ceramic Pads / Breyton BE Wheels
    VIP Member Kermit's Avatar
    Va. Beach, VA
    WOW, Looks like you need to get some after market mufflers there Henry!!!!
    2009 G8 GT MGM.
    Performance - 1900 MagnaCharger , Lunati Cam, RCR Ported Heads, Intake and TB, FAST #65 Injectors, CTS-v fuel pump, Kooks 1 3/4" LT and Catted X-Pipe, Pypes Violator Axel-Back, Roto Fab CAI, RX Oil Catch Can, Pedders XA's & Track II Bushings, BMR Sub Frame Connectors, Sway Bars & Rear Control Arms, 19 Inch Staggered (8.5 front/9.5 Rear) VMR 810 Wheels, DBA 4000 Sloted Rotors with Hawk HPS Pads & Russels Brake Lines, Camaro 3.27 Diff, Gforce Axles.
    VIP Member G8 GT V8's Avatar
    Fairfield, Ohio
    Holy sheeeet!!! Guess they become way more restrictive at your horsepower level. For us with the mild builds, probably not as much to be concerned with, but damn that made a big difference. Thanks for sharing this info...
    Marty
    G8 gone, but not forgotten...
    Friendswood, TX
    It sure as hell got my attention! :-). I'm going the Magnaflow mid muffler and Cherry Bomb Vortex route. I was "floored" at leaving 49 ft lbs of torque on the table - and in my sweet spot of daily driving rpm! Yikes Batman!
    Never would have thunk it would be that bad.
    RCR ported heads - RCR Lunati 219/231 113+1 - LSA Crank - Molnar rods - Racetec pistons
    Kooks 1 7/8 LT - Solo 3" CB - 3.27 diff w WaveTrac MT DRs + M&H FRs on Weld RT-S
    Old 10.09@138.8 1.51 60'
    New ?@? 716 rwhp 652 rwtq
    Sep 2009
    VT
    From PatG back in 2010
    Sport /Premium
    Beyond Help gr8lover's Avatar
    SE Michigan
    Suprised you still have stock muffs.... but yea thats alot!!1
    I dont think people have a clue on how much power can be killed with undersized exhaust.....
    I just recently put on 3" muffs instead of the 2.5" mufflers I had... (had a full three inch system going down to 2.5" muffs...)... ARH and other shops said it wouldnt make much of a difference..........
    After I did it, I went from 835rwhp to 921 rhwp...... i was absolutely shocked!!!!!!!
    Dec 2013
    phx az
    you really drive your car with the gas pedal FLOORED between 2700 and 4200rpm ?
    you would only be using that range floor at the track , not on the street in normal average conditions
    SE Michigan
    Quote Originally Posted by s/c'd cav View Post
    ..when he accelerates from a stop light he will have more power...... ... not sure what your point is.... he will be in that power band even accelerating from a light or cruising then hitting the gas...
    Dec 2013
    phx az
    well since when have you ever seen anyone on a dyno , test in your average daily driving use ?
    ive seen it done , NOT NEVER EVER !!!!!!
    so in the real world , all the dyno is showing he will loose time(ie slower) at the track , so it shows nothing on how the car is driven in light throttle use
