damn. cutouts would be an good option if u wanted to keep sleeper status but go ham on a push of a button..
Blown by JessikaTuned by Pat G"Stock" MGM G8
No kidding!!! :-)
Mid muffler delete and bi-modals gets you the best of both worlds.
Naturally as-pirated
Thanks but really want the mid muffler to eliminate drone. If I fall short on hp because of the mid muffler - in good with that. I just can't live with drone. It drives me nuts! Concession being made.
Drone is fixed with either stock AFM silencers or HSV bi-modals at rear. Else ~27" capped pipes on any system will do the trick - performance without the drone that is.
Nah set up an alert for "HSV bimodal" on eBay, I paid $250 for a take-off pair HSV bi-modals - they are stainless so doesn't really matter.
Not that hard to ship either, couple of hundred to US. Hook it up with mildtowild controller for $200 or DIY switch for about $50.
I have dynoed open (mid muffler delete) and closed and there's no difference until 3000 RPM, have detailed chart if you like.
Lister to this with headphones or hifi with LFE / sub:
