cts-v calipers left to right
Getting ready to do my brake upgrade cts-v brembos and was wondering if the right and left caliper for the front are the same. I know I would have to move the crossover tube and the bleeders. Just don't know if the bolt holes are the same, mounting location yada yada yada.
Different.
The Pistons are different sizes and the small piston is the leading one. The reason it to get even pad wear.
[QUOTE=BuildItYourSelf;590864]Different.
Ok but I thought that the front calipers had the same size pistons. I know the rears do that's why you swap the cross overtubes and bleeders and then install on the opposite side.
Nope. Same concept applies to the front. And pretty much every multi piston Caliper.
Four part numbers. One for each corner.
- You may not post replies
- You may not edit your posts
Forum Rules
