Results 1 to 10 of 10
Thread: Jeremy said it: It's official - New HSV
    VIP Member pir4te's Avatar
    Oct 2011
    Barossa Valley, South Australia
    Default Jeremy said it: It's official - New HSV
    There's a lot of commotion on Aussie boards about the last of the Zeta (G8) platform from now until 2017, what is being developed to replace it, and should it still carry the Commodore moniker.
    Here's the new HSV version, based on what the new "Commodore" will look like:
    Apex, NC
    Well that's a beauty; hope it's true!
    Wrong wheel drive & powered by 4 ferrets.
    No thanks.
    Body is beautiful. Engine swap special.
    Oct 2011
    It fits the V6 turbo so I think V8 would fit?
    Beyond Help tchr49's Avatar
    michigan
    Agreed, but the press release looks like something from the National Enquirer...
    Jan 2011
    Flint, MI
    Man that is sharp.
    AWD would be nice, but if it became an option to have v6/awd or lt1,lt4/rwd, I would still skip the v6.
    Front end reminds me of the Audi R8. Like those too!
    Senior Member GRRR8GT's Avatar
    Spruce Grove.AB. Canada
    I think she looks sweet and those ferrets in my Regal pull 75 ponies each. If only I could get any traction...
    09 GT PBM Base,6K HID's and relay harness, Homelink in visor, sport pedals, GXP rear valance, Pontiac trunk liner
    Infinity's in doors, Kickers on Deck powered by EXILE and 16OHM center spkr, 40' of dynamat, Weathertech floor liners
    20" Rial Porto's with 245R35 front and 275R30 rear Sumutimo HTRIII's and CTS-V Brembo calipers with DBA Rotors and SS lines.
    Pedders GSR struts with OEM height Sport Ryder Springs and SuperPro bushings. DOD deleted.
    Solo HFC's with Mach Balanced w/J pipes and resonators + 3.5" tips, Harrop Enhanced Performance with EPS custom cam
    Tuned by Patrick G. and cooled by B&M
    "Jack"
    winter 2015 mods....TBD
    New DD 2013 Buick Regal GS, Diamond White, IPF Tuned...
    Lebanon,Indiana
    That looks pretty good
    Friendswood, TX
    I'm impressed!
