Do anyone know where I can get the rear ctsv brake caliper brackets for use with the camaro roots? Squash and pace both don't sell them anymore
Wait and see if the Chevy ss rotors work first.
There close the same price and need no bracket and park brake works.
Not sure if you knew about them or not.
2008 GT-M. PBM, #885
I'm guessing that the OP already has the CTSV calipers hence the need for the brackets...with that said, it still might be worthwhile selling the calipers and going with the 2015 SS setup.
Marty
G8 gone, but not forgotten...
They're the same calipers.
You've confirmed this?
There appeared to be some uncertainties in this thread at post #48:
http://forum.grrrr8.net/showthread.php?t=41344
Marty
The Camaros have a little notch cut in them to clear the knuckle. But both fit directly to the g8 knuckle with the hsv rotor.
I have the v1 rear with hsv rotor. The ss rotor is the same as hsv (once they get received that will be cleared up to be 100% true but the blokes down under use them) but a little bigger in diameter so the pad don't need trimmed.
Well if Greg is talking about them working with the rear knuckle then yes they bolt on.
He said the ss and g8 have the same knuckle and I have rear v1 brembos on mine so they should. Unless I'm missing something that he's talking about.
I do remember someone along time ago saying about the notch and they cut them in the v1 rears. But I don't think it was necessary.
And I didn't see the updates on that thread looks like the answer is just around the corner.
ive got brackets im not using(if interested let me know) , i decided to use other rotors
friend of mine made them and made structural changes to what squash had made
