Page 3 of 9 FirstFirst 12345 ... LastLast
Results 21 to 30 of 86
Thread: LSA Blower Install (complete parts & install tips)
  1. #21
    Jul 2010
    Castle Rock, CO
    Why LSA swap?? Cheaper compared to Maggie, or more/better performance compared to Maggie and Prochargers?
    09 G8 GT in Stryker Blue
    Mods
    Go: Vararam CAI, SLP Headers, Magnaflow 12468 mid-muffler & PM-FL Axlebacks. Tuned by MAC Autosports of Parker, Colorado. FE3 Shocks N Struts.
    Show: Little Trees US Flag Vanilla Scented Air Freshener; SLP G8 Firehawk wheels; tinted windows
    The Track
    Best 1/4: 13.969 @ 102.70 @ Pueblo Motorsports Park, w/ DA of 3921'.
  2. #22
    Senior Member glanzergtx's Avatar
    Sioux Falls, SD
    Quote Originally Posted by wyome View Post
    Cheaper than the Maggie and more low end torque. Procharger is no comparison between the LSA & maggie.
    http://forum.grrrr8.net/signaturepics/sigpic7818_3.gif
  3. #23
    Dec 2011
    Dallas, TX
    19303635 - Supercharger w/snout and pulley
    19180859 - bypass valve with bolts (actuator not needed)
    12622236 - ZL1 Lid with bolts, sensors, IC, seals, fittings for IC hoses
    12639188 - EVAP solenoid
    12603916 - Balancer (crank pulley)
    12557840 - Balancer Bolt (x1)
    12606501 - Idler Bracket
    11588727 - Idler Bracket bolts (x3)
    12606031 - Idler Pulley
    11518630 - Idler Pulley Bolts (x2)
    11900254 - Idler Bracket bolt (x1)
    12606032 - Idler Pulley
    12606500 - Tensioner Bracket
    11588749 - Tensioner Bracket Bolt (x2)
    11588742 - Tensioner Bracket Bolt (x1)
    12622452 - SC Tensioner
    11588753 - Tensioner Bolt (x1)
    12636227 - Stock SC belt for stock pulley sizes
    22879421 - ZL1 Heat Exchanger
    19180613 - LSA Intake manifold gaskets
    12612467 - IC insulator
    11588718 - Supercharger bolts (x10)
    12622235 - Fuel Rail
    12598646 - LSA Injectors (x8)
    Seems to be everything you need
  4. #24
    Sep 2009
    VT
    Sport /Premium
  5. #25
    Sep 2009
    VT
    Sport /Premium
  6. #26
    Senior Member 4d00rv3tt3's Avatar
    Sep 2014
    Richmond VA
    these lists are a great source for reference. keep em coming. i for one would like some options for a better HX, since these are prone to heat soak. i dont think with this style blower youll ever get rid of that problem, but if it will run a little cooler than why not explore options? keep em coming guys all this talk is making me want to order more parts haha.
    Bolt Ons/tune-12.90@108.51 2.002 60ft.
    P/B-Cam only 12.14@115 1.9 60 Ft
    PB with blower@7#s-11.7@124 1.8 60 Ft
    PB with blower@12#s-10.9@127 1.62 60Ft still stock converter and trans!
    +built trans/ZL1 converter 10.63@130.97 1.58 60Ft
    full weight with stock 19s on front!!!
    with cam-431Hp/400Tq
    with LSA@7.5#-581Hp/495Tq
    With LSA @12#-589Hp/552Tq
    with LSA @12# and more timing-unknown
  7. #27
    VIP Member bryand's Avatar
    Apr 2013
    Sheridan, AR
    This is a great thread. Subbed for the info.
    2009 W/H G8 GT
  8. #28
    Nov 2011
    Cincinnati,OH
    Here is how I handled the ground stud on the passenger side...
    I scoured the local U-Pull for a stud I could use in the idler bracket and came across this:
    Top is the stud I found and bottom is the factory LSA bolt. It's an alternator bolt off a series III 3.8L found on many fwd gm cars. Turns out it's just a bit too long so I knocked off about 6 threads and this is what I finished with:
    Makes for a nice mount for the ground and because it indexes on the hex, it can be twisted up and away from the exhaust.
    The bolt is PN: 24507943.
    Phillip M.
    Engine: Stock Bottom End
    Cam: BTR IV PD
    Drivetrain: 6L80, Sonnax
    High Compression/Boost/E85
  9. #29
    VIP Member G8 GT V8's Avatar
    Fairfield, Ohio
    That's pretty slick Phil...
    Marty
    G8 gone, but not forgotten...
  10. #30
    Sep 2009
    VT
    My passenger side ground solution was to use the stud that holds the dipstick.
    Sport /Premium
  11. Likes SpeedDemon liked this post
