Results 1 to 10 of 14
Thread: Intake Manifold Heat Shield
    Oct 2009
    Webster, NY
    Default Intake Manifold Heat Shield
    Is anyone on here running one of these shields? Do they really work and decrease temps?
    Jon
    2008 NA G8 GT
    1/4 mile = 10.93 @ 123
    60' = 1.47
    DA = 500
  2. Thanks pir4te thanked for this post
  3. #2
    Didn't know it existed.
  4. #3
    Oct 2009
    Webster, NY
    It does. I have heard a little bit about it, but I'm not sure if it would really work. It might be worth a shot for 50.00
    2008 NA G8 GT
    60' = 1.47
    DA = 500
  5. #4
    VIP Member Ben2009GT's Avatar
    Puyallup,Washington
    It's worth a try anything that can deflect heat away has to help. My car is apart I'll buy it and will see.
    515 rwhp - 416 Stroker - 2015
    2009 G8 GT PSP, 6.8L Stroker 416ci,CM 228/234 .629/.629 LSA112 +2 Cam,PRC LS3 255CC CNC Heads,Trunion Rocker Upgrade,RCR Intake,FTI Stall 3600-3800,Trans Cooler,B&M flex plate,3.27 Diff LSD,UDP,1 7/8 OBXR LT SS Headers/SS, 3",Borla Mufflers,VCM OTR CAI,LS7 MAF 100mm,Patrick G. ECM/TCM Tune,Koni Shocks/Struts Yellow,Eibach Pro Kit Springs,LCA's w/Whiteline bushings,BMR Sub Frame Connectors,Spohn Tunnel Brace,BMR Fr/Rr Sway Bars,Suspension/Diff Bushings,PMT Rear Trailing Arms/Toe Links,Brembo's Front Brakes,Russell Street Legal Brake Line Braided SS,V8 6.0 Side Badges,GXP Diffuser,G8 Door Sill Plate,Red Shift Knob,SS Rim's,BFGoodrich g-force 255/35/20-285/35/20
  6. #5
    merca!!!
    I think it won't make much of a difference.
    I mean the intake is bolted to the heads. And it's plastic anyway. It only absorbs so much and I'm sure the heads send the most heat into it. I think an air gap is just as good.
    Seems it will only block heat radiation. And how much does the valley cover give off anyway.
    One of those things that wouldn't hurt just may not be needed.
    2008 GT-M. PBM, #885
  7. #6
    Oct 2009
    Webster, NY
    I was thinking the same about the heads.
    2008 NA G8 GT
    60' = 1.47
    DA = 500
  8. #7
    Puyallup,Washington
    On there site they claim up to a 12rwhp gain. because of the heat difference.
  9. #8
    Oct 2009
    Webster, NY
    I see that. Would be cool if it was true. That's why I'm thinking it would be worth a shot for 50.00.
    2008 NA G8 GT
    60' = 1.47
    DA = 500
  10. #9
    merca!!!
    I think the 12hp is bs
    I'd have to see the proof of that one.
    Id say it's worth buying a piece of heat shield and cutting it to fit for $10 over this. Unless you don't mind spending the extra money.
  11. #10
    Heat soak is heat soak. It may allow it to take longer to soak, but soak it will! Let's put it this way... There are MANY cars running 10's without one.
