Need any advice if this is a know simple fix. My remote start is not working.
1) All doors are locked
2) I press twice on the lock to get the Horn chrip
3) WHen I then press and hold the remote start button, the lights blink but I do not get the click and sound of the fuel pump coming on which I used to.
Other then that everything is perfect that I know of. No check engine codes that I am aware of.
COuld it be a fuse? If so which one as the fuse block under the hood di not have a specifically marked remote start fuse.
If there is a code, is there a way to get the DIC to display it or any way to get it with out getting a scan tool?
Thanks for any info
