Results 1 to 5 of 5
Thread: Fog Light upgrade question
    Senior Member piecesparts's Avatar
    Jan 2009
    Default Fog Light upgrade question
    Has anyone changed out the fog lights to an aftermarket assembly? I want to do something to change the fogs to an LED llight, so that they actually give off some useful light. I presently have Vision-X LED lights in the fog lights for my 2011 GMC truck, but am curious if anyone has done anything to make a change to the G8s. My intent is to change out the whole assembly and this would require a different mounting bracket.
    Sep 2011
    you can just buy an led bulbs and put them in to the same housing
    Jan 2009
    The replacement LED bulbs are no match to what I want in my fog light area. The ones in my truck light up the world half a mile down the road.
    Junior Member Z28nut's Avatar
    Nov 2014
    Tejas
    I converted my '94 Z28 over to Hella 90mm headlights and when I got the G8, I ordered a set of Hella 90mm fog lights. About to go do an HID conversion on it today so will be able to look at how much of the stock mount is going to need to be cut off. Didn't really want to cut stuff up but I had to on the Z to make it work.
    Beyond Help texn884's Avatar
    Helotes, Texas
    Quote Originally Posted by roman1978 View Post
    Where can you get the led bulbs?
