Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: Front swaybar endlink replacements
    Jan 2013
    Indiana
    Default Front swaybar endlink replacements
    I need to replace the front endlinks. I am looking at the moog or the whiteline basic replacements. Since they are both the same price are there any pros/cons to each? The whiteline are not the thicker adjustable ones just the basic replacement.
    Thanks!
  2. Dislikes s.reef disliked this post
  3. #2
    Beyond Help SRG963's Avatar
    Charlotte NC
    To grease, or not to grease, that is the question.
    Trigger
    PRAISE THE LOWERED
  4. #3
    I found the moog's to be significantly cheaper
    rock auto was something like 17 per side. so both fronts in my hand was 36 dollars.
    whitelines were going to be something akin to 80.
    I bought moogs - and I've greased them just once.
  5. #4
    Jan 2013
    Indiana
    Rockauto prices must have gone up. They are $23 and some change each. Whitelines I can get them for $46 dollars shipped. Moog will be $53 shipped. Basically a wash at this point. I was leaning towards the moog because I can get them through amazon prime and have them before the weekend guaranteed.
  6. #5
    huh. are you sure you're looking at the right parts? the camaro parts aren't the same as the g8 here.
    but otherwise - either way really. both will work. I've not held the whiteline endlinks but the moog ones were thicker and stronger in all areas vs the stockers.
  7. #6
    Jan 2013
    Indiana
    As far as I know. I pulled the part numbers right off of rockauto.
    MOOG Part # K750162 {#92159356} Problem Solver One of our most popular parts
    Front Left; Incl. powdered-metal gusher bearing to allow grease to penetrate bearing surfaces
    MOOG Part # K750163 {#92165959} Problem Solver One of our most popular parts
    Front Right; Incl. powdered-metal gusher bearing to allow grease to penetrate bearing surfaces
  8. #7
    I'll go with the MOOG when I need to replace mine! Hard to beat for the moola!
  9. #8
    Jan 2013
    Indiana
    That is what I ended up buying. Will be installing this weekend.
  10. #9
    Jan 2013
    Indiana
    Comparison pic of the stock vs the Moog. I swapped this morning and no difference in the clunking/chattering noise. I guess my only other option is the control arms since I have BMR poly strut mounts and new bearings.
  11. #10
    Apex, NC
    Quote Originally Posted by Rylos View Post
    My clunking noise ended up being loose nuts on the front sway bar brackets; if you haven't tried tightening them, I'd give it a try.
