Page 3 of 17 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 163
Thread: New rear direct fit Brembo rotor from the 2015 SS
  1. #21
    Jul 2014
    Subd
  2. #22
    Senior Member solty's Avatar
    Ann Arbor MI
    Very interested. Subd
    2009 G8 GT Silver Metalic with Premium Onyx/red - Sunroof - Sport package - Vararam intake - DOD delete - Livernois 2C cam - Kooks Mids 1 7/8" - Corsa cat back - Pedders Xas - triple Gauge - Blue tooth module - VIM
  3. #23
    Texas
    Any updates on this?
  4. #24
    Just need to wait for GM to start stocking parts for the 2015 SS...
  5. #25
    Boardman, Ohio
    Only update I currently have is the SS rear Brembo caliper is the same as the Camaro SS rear Brembo caliper.
    The rest of the parts are still not shipping to dealers.
  6. #26
    Only update I currently have is the SS rear Brembo is the same as the Camaro SS rear Brembo.
    Are you referring to the caliper or rotor?
  7. #27
    Boardman, Ohio
    Caliper
    Sorry I'll edit.
  8. #28
    Jan 2013
    Indiana
    I have a set of brackets and ebrake shoes I've not installed because I'm waiting to see how this rotor solution pans out.
  9. #29
    VIP Member pir4te's Avatar
    Oct 2011
    Barossa Valley, South Australia
    Mate looked up 92267114 here
    New number 92281427 AUD$288.75 retail. US$245.24.
  10. #30
    Capitol City G8 G8V8's Avatar
    Jacksonville, FL
    Does anybody know if the rear hub is the same for the '15 as the '14?
    If the caliper is the same as the Camaro SS then one of the following conditions must be met for everything to bolt up and fit:
    1) The '15 Chevy SS rear rotor must be smaller in diameter than the Camaro SS rotor, or
    2) The '15 hub is different than the '14 to move the caliper outward from the hub.
    Here is my confusion:
    Camaro SS rear rotors are 365 mm. G8 GT rear rotors are 324 mm. The DBA HSV rear rotors that I had on my G8 fit and allowed the 4-pot rear Brembo calipers to bolt directly to the G8 hub (no bracket req'd, stock e-brake fits) BUT the caliper was a little too far from the hub which meant that the brake pads over hung the rotor by 2-3 mm. We dealt with this by trimming 2-3 mm off of the outermost edge of the pad. Had the rotor been 4-6 mm larger (probably 355 mm) or the caliper mounted 2-3 mm closer to the hub, this would have been a perfect fit.
    So, it would seem, IF the '015 hub is the same, dimensionally, as the G8 and '14 Chevy SS rear hub, a 355 mm rear rotor based upon the design of the HSV rear 350 mm rotor should work just fine and need no bracket or custom e-brake shoe.
    BUT THEN I SEE THIS ADS:
    http://www.ebay.com.au/itm/VE-VF-HSV...-/171542693343
    They say this is a bolt-on upgrade for the VE and VF. It uses 4-pot Brembos and 350 mm rear rotors. How can this not have the same overhanging pad problem we do when fitting a 350 mm HSV rotor to a G8?
    From our experience, there is something missing with this conversion. The dimensions do not add up or they are not telling you the pads are special or modified or need to be modified to fit and not overhang a 350 mm rotor. OR, the Ve & VF in Australia use a slightly different hub (very unlikely, IMHO).
    Attached are drawings of the VE (G8), Camaro SS and HSV VE rear rotors. You can see the in and out location of the disk relative to the "drum" varies with the application. The HSV disk location, from experience using it, centers up on the caliper very closely when the Brembo is bolted directly to the hub. The Camaro SS disk location requires a bracket/space. The bracket/spacer not only positions the caliper out far enough to work with the 365 mm Camaro SS rotor, it also shifts the caliper sideways to align with the center line of the rotor.
    Wow, did not mean for this to ramble on and on.
    My conclusions:
    1) '15 Chevy SS will use a 355 mm version of the HSV 350 mm rotor and everything will be peachie! (Great for G8 conversion.)
    or
    2) '15 Chevy SS will use the HSV 350 mm rear rotor and will have rear hubs with different caliper mounting locations to move the caliper 2-3 mm closer to hub. (Not so great for G8 conversion.)
    or
    3) '15 Chevy SS will use the 350 mm HSV rotors with some pads that have a narrower contact patch so they don't overhang the rotor edge. (OK for G8 conversion.)
    or
    4) contrary to what has been stated, the calipers are slightly different with their mounting holes moved to position the caliper the correct distance from the hub to align with the 350 mm rotor edge. (Should work for G8s but calipers will be unique, not Camaro SS or CTS-V.)
    Anyway, these are just some ramblings of an old man. Take them for what they are worth. LOL
    Attached Files Attached Files
    HSV E3 Bumper and Fenders
    VMS DoD-Delete with heads
    TVS1900
    RCR TB
    Kooks 1 7/8 Mids+SOLO Mach
    ZL1 Brakes
    Roto-Fab
