Page 2 of 17 FirstFirst 123412 ... LastLast
Results 11 to 20 of 163
Thread: New rear direct fit Brembo rotor from the 2015 SS
    Quote Originally Posted by kevinm0131 View Post
    I may upgrade now that it's a simple swap, it seemed like the other swaps were a bit tedious and problematic.
    Exactly why I never even contemplated it until now. One thing I like to KNOW is working, are brakes. I don't need to have unforeseen issues with them.
    Jan 2013
    Indiana
    So is this a smaller diameter rotor? The bracket was to compensate for the larger diameter rotor was it not?
    Also guessing this will fit the e-brake because the inner hub is the correct diameter now as well?
    This rotor is 5mm smaller in diameter, 1/10 inch smaller radius.. The adapter bracket's biggest dimensional change was to space the caliper further outboard almost 1/2 inch. The SS rotor will be slightly smaller in diameter and have the rotor faces properly located to not need the adapter's 1/2 inch step out.
    merca!!!
    Not to mention more clearance for wheels.
    The bracket made the Caliper stick out further then the front.
    I got the hsv rotor for that reason and the rotor will last the life of my car. And who cares you have to shave the pad a bit.
    2008 GT-M. PBM, #885
    VIP Member kevinm0131's Avatar
    Nov 2008
    Oxford ohio
    so what's the word on these? Anyone?
    Kevin
    2009 SRM G8 GXP A6 + Roof
    Go
    Vararam CAI
    VMS "Stealth" Dyno Tune
    VMS HSRK
    GTPprix's hacked Atari gauges
    Doug Thorley LT's
    Show
    PB
    12.986 @ 108.78
    Member BFI91's Avatar
    Sep 2014
    Illinois/Virginia
    This makes things cheaper lol...nice find!
    2009 LR G8 GT
    Varraram intake, LS7 maf, SLP underdrive pulley, granatelli 0 ohms resistant 10.5 wires and coil packs, PYPES 1 3/4 tri y long tubes, OBX x pipe no cats, flowmaster 44 with 4" quad tips, camaro 3.45 rear end, BC coilovers, BMR lower control arms, BMR tow rods, BMR trailing arm, BMR subframe connectors, BMR tunnel brace, BMR strut tower brace, BMR front sway bar, BMR rear sway bar, spyder rear tail lights, powder coated black camaro rims
    6.2L engine swap
    Rick Crawford special
    Ported polished and milled heads (11.6:1) with LS9 valvetrain, RCR intake, RCR throttle body,DOD delete,CTSV racing lifters, 111 lunati cam, 3000 triple disk coan stall
    2011 yellow ctsv brake upgrade
    Formerly owned by Scorpion
    Boardman, Ohio
    Just waiting for GM to release them. I'm guessing it might be a little longer since they are not even building the 2015 SS yet.
    Senior Member KDRobb's Avatar
    Peoria, IL
    So will this rotor work with the current rear Brembo & bracket setup? I would like to go this route instead of the custom brake shoes
    2009 MSM GT
    Roto-fab, OBX, Solo, VMS 1.5 cam, Brembo's, Staggered VMR 710, Eibachs, BMR Sways, TVS2300, AIS meth injection, and RCR tuned
  9. #19
    With these new rotors, you remove the rear bracket. It will no longer be needed
  10. #20
    Senior Member PMD G8's Avatar
    Feb 2009
    Subscribed. I was already thinking about adding rear brembos to my GXP this winter.
    MSM/Onyx GXP A6 w/Roof
    Purchased: 5/29/09
    Mods:
    CTS Auto-Dim Mirror, Homelink in Visor, Hacked Atari Gauges, Nuvi 660, Hawk Pads, Roto-Fab Intake, and a bunch of other stuff....
  11. Likes lVloses liked this post
