Page 16 of 17 FirstFirst ... 614151617 LastLast
Results 151 to 160 of 163
Thread: New rear direct fit Brembo rotor from the 2015 SS
  1. #151
    Beyond Help tchr49's Avatar
    michigan
    Thanks everyone. I think I got all straight in my old head.
    Now to remember it all.......
  2. Likes -Ray- liked this post
  3. #152
    Member jstclair's Avatar
    Jan 2016
    Colorado
    OK, so I found a set of rotors on Fleabay, correct dims for the Camaro/CTSV 4-pot caliper and G8 parking brake. My understanding is the Camaro SS rear Brembo is a bolt on IF the rotor has the correct dimensions.
    No adapter needed, correct? I already have the complete CTS-V setup for the front so plan to do the entire thing at same time... thanks!
  4. #153
    Dec 2013
    phx az
    if they are 15-17 SS SEDAN rotors , then the calipers need nothing else to fit beside the correct length bolts
  5. #154
    Jan 2016
    Colorado
    Quote Originally Posted by s/c'd cav View Post
    What about the 10-15 Camaro SS rears? Supposed to be the same pattern as the older CTS-V, different color and lettering.
  6. #155
    Dec 2013
    phx az
    ITS NOT THE CALIPERS that matter its the ROTORS
  7. #156
    Jan 2016
    Colorado
    I have the correct rotors from another source; just trying to verify which calipers will bolt on to the G8 rear spindle.
    These are aftermarket 14 in od, slotted and drilled, with the correct center for the stock G8 parking brake and bolt pattern.....
    *** edit ****
    ok, I verified with the vendor that has the rotors, that the 2010-2015 Camaro SS rear Brembos bolt on. Answers that!!!
  8. #157
    Dec 2013
    phx az
    any of the 4 piston REAR calipers
  9. #158
    Jan 2016
    Colorado
    Correct.
  10. #159
    Jan 2016
    Colorado
    So finished the upgrade finally. No more shudder on hard braking.
    Front: CTSV kit from ZZPerformance, all new parts
    Rear, rotors and caliper bolts from ZZPerformance, calipers from 2012 Camaro SS
    Braided brake lines from Goodridge
    Painted red since they didn't match in color or logo; factory caliper bolts for SS a too long, hence the shorter replacements
    Pics are front with wheel
    Rear
    factory size and new 14 rear rotors
  11. #160
    May 2017
    Lima, Ohio
    Looks great! I want to do this swap as well... About how much do you have wrapped up it it?
