Page 15 of 17 FirstFirst ... 51314151617 LastLast
Results 141 to 150 of 163
Thread: New rear direct fit Brembo rotor from the 2015 SS
  1. #141
    Jun 2016
    Quote Originally Posted by PPV View Post
    I recently installed 2015 SS rotors and calipers using break performance rotors. Good product so far.
    PPV, What lines did you use to install the brembos on your Caprice?
  2. #142
    Jul 2011
    Gilbert AZ
    Are the VE HSV rotors people were using prior the same size as SS rear brembos or a hair smaller??? Am I hearing there is no need to trim the pads anymore with 2015+ SS rotors??
    09.1 G8 GT, 20x9/10 Red G wheels, magnaflow catback, DT's, Crawford ported TB/manifold, Spectre 4"/LS7 MAF, Rotofab, HID's, Aussie SV6 tails, GXP rear diffuser, BMR strut bushings/cradle inserts, BMR sway, Megan Coils, CTS-V 6/4pot Brembos, HSV steering wheel.
    http://i92.photobucket.com/albums/l4...psce2f18b1.jpg
  3. #143
    The HSV rotors had a slightly smaller diameter measurement made to work with a different caliper found on the HSV... The SS rotors are correct and made for the Brembo rear calipers.
  4. Likes pir4te liked this post
  5. #144
    Beyond Help tchr49's Avatar
    michigan
    Can someone light the candle for an old man?
    I was fine until I tried to order from a brake place.
    I have 2014 Camaro rear calipers and plan to use them with 2015 Chevrolet SS rear rotors.
    Are the rear calipers for the 14 Camaro and the 15 SS the same? (Gal tells me pads are different)
    I'm using front 04-07 CTS-V calipers (172-2287 and 2288).
    I see that 2015 SS front rotors and GXP rotors are the same.
    Are the older 4 piston Caddy calipers and 2015 SS calipers the same? (Got the same story, pads are different)
    I think the problem is in their parts numbers?
    Thanks
  6. #145
    Dec 2013
    phx az
    the SS had dampers on the pads , where the camaro rears do not , just their fronts
    other wise pads are identical , and swapable
  7. #146
    Get the pads without the roller skates. They are a pain to clean around and look stupid.
  8. #147
    michigan
    So last question because I'm buying both ends at once
    2015 SS and 04-07 ctsv/Gxp front calipers are the same?
    Thanks folks
  9. #148
    I cut them off my pads.
  10. #149
    michigan
    Thanks folks
    So back to this, do the 2015 SS and 4-7/Gxp the same calipers and take the same front pad?
  11. #150
    Boardman, Ohio
    They are not the same caliper, but do take the same pad
