Results 1 to 2 of 2
Thread: ASWC-1 programming issue
    Mar 2014
    Default ASWC-1 programming issue
    HI all,
    I have an ASWC-1 connected to a sony headunit in my car. the problem I am having is the button on the left side of the steering wheel with the road on it used to toggle the menu in the DIC triggers the bluetooth button whenever it is pushed. I updated the firmware on the ASWC-1 and I still have the same problem. everything else works fine except for that button. I also checked my wiring and the plug is all the way in on the back of the radio. any one else have this issue or can help????
    Mar 2014
    also for anyone that has programmed one. when the instructions say push and hold the volume up button sense ours "roll" did you roll it or just hold it down?
