Results 1 to 4 of 4
Thread: new keys
    Jul 2014
    Default new keys
    I bought two new flip keys and I have tried just about everything to get them to take to the car. Nothing works.
    I read the manual, step by step. Nothing. I researched and did the 30 min. Relearn... nothing. I can get the fob to work on the car but as soon as I put the key in I get the engine immobilized prompt on the dash telling me to refer to the owners manual. Been working at this for months on and off.
    My guess is that there have already been four keys programed to my car. Just looking for some input. Maybe you guys can help me out.
    I drive an 08 GT.
    Banned
    Oct 2013
    Dix Hills, NY
    You need to program the old working keys along with the new one, then program the old fobs with the new one. Any fob not programmed will be erased. Are you sure the new key turns to all positions?
    Programming the key:*
    To program a new section (A):
    1. Insert the original, already
    programmed key into the ignition
    and start the engine.
    If the engine does not start, see
    your dealer/retailer.
    2. Remove the key from the
    ignition.
    3. Insert and turn the new
    section (A) to ON/RUN within
    five seconds of removing
    the original key.
    4. Turn the new section (A) to
    LOCK/OFF. Section (A) is
    now programmed.
    Programming the fob:
    To program a new section (B): Remote
    1. Turn the ignition to ON/RUN with
    the new section (A).
    The vehicle must be in
    PARK (P).
    2. Select Remote Key from the
    personalization menu.
    3. Select Program.
    4. Press Unlock and Lock on the new
    section (B), at the same time,
    until you hear two beeps.
    5. Repeat Step 4 for all other keys,
    including keys that require
    programming or ones previously
    programmed to the vehicle.
    Any key not reprogrammed will
    be erased.
    6. Turn the ignition to LOCK/OFF.
    keyfobchip.jpg Did you check the key for the chip.
    Mar 2012
    seattle
    Where did you get your keys from? Cost?
