Results 1 to 5 of 5
Thread: Bulletin Update
    Default Bulletin Update
    2006-2008
    Corvette, Escalade, Escalade ESV, Escalade EXT, G8, H2, Sierra, Silverado, STS, Suburban, XLR, XLR-V, Yukon, Yukon Denali, Yukon XL, Yukon XL Denali -- Slips in Reverse, delayed Reverse engagement, DTC P0776, harsh 2-3 shifts
    Inspect the 1-2-3-4/3-5-R housing for a cracked weld
    Do Not Replace the transmission without inspecting the 1-2-3-4/3-5-R housing for a cracked weld
    Reference Information / Bulletin Number PI0536A
    http://www.archivedsites.com/techlin...onditions.html
    2006-2012
    All Vehicles --COAX repair kit availability
    Utilize the coax repair kit to reduce vehicle down time
    Do Not Order complete wiring harnesses for OnStar, XM, and navigation antenna coax concerns
    Reference Information / Bulletin Number PI0572
    2008-2009
    G8 -- Grind noise from front of vehicle when turning steering wheel
    Replace mount and bearing together
    Do Not Replace mount and bearing separately
    Reference Information / Bulletin Number PI0140
    2005-2012
    All Vehicles -- Warranty code generated by El-50313 Midtronics GR8 battery tester/charger required for claim processing on labor operation N0110 and battery part restriction
    Install revised software to correct "Loss Of Communication" issue with GR8. Availability information provided in bulletin
    Failure to upgrade the software can cause unnecessary test restarts
    Reference Information / Bulletin Number 03-06-03-004E
    2011-2012
    Caprice PPV -- No power to front passenger foot well (upfitter) auxiliary 12 volt battery power supply
    Attach blue connector and auxiliary battery
    Do Not Hook up aftermarket at UHBEC
    Reference Information / Bulletin Number PI0587
    2006-2012
    All Vehicles - Service Programming System (SPS) errors
    Follow SPS tips before programming to ensure a successful programming event
    Do Not Program without following SPS programming tips
    Reference Information / Bulletin Number PI0592
    2008-2011
    Camaro, Caprice PPV, Cruze, Equinox, G8, LaCrosse, Regal, Terrain, Volt - Key cutting procedure for obtaining replacement key
    Information only
    Reference Information / Bulletin Number 09-00-89-029G
    2006-2011
    G8 - Coolant loss from cylinder head coolant bleed passage
    Seal cylinder head coolant leak with bolt on cover
    Do Not Replace cylinder head
    Reference Information / Bulletin Number 11-06-02-001
    2011-2012
    Caprice PPV -- USB Diagnostic Cable EL 50334-10 required when reprogramming radio
    Purchase USB Cable and perform radio programming
    Do Not Replace radio for software updates
    Reference Information / Bulletin Number PI0485
    2004 - 2011
    Acadia, Camaro, CTS, Enclave, Equinox, G6, G8, LaCrosse, Malibu, OUTLOOK, SRX, STS, Terrain, Torrent, Traverse, VUE -- Intermittent engine hesitation or flutter without DTC
    Inspect and correct intake CMP sensor bank 1 connector terminals for intermittent conditions or poor connection
    Do Not Replace ECM or crank sensor
    Reference Information / Bulletin Number PI0090B
    2008 - 2012
    All Vehicles -- Rear vision camera display concerns - distortion, blurry or fuzzy video image
    Clean the lens of the camera
    Do Not Replace the camera
    Reference Information / Bulletin Number PI0385
    2008-2009
    G8 -- Automatic transmission 6th gear whine
    Install new transmission mount
    Do Not Replace any other front suspension parts
    Reference Information / Bulletin Number 10-07-30-012
    2006-2010
    Lucerne; DTS; Escalade; Escalade ESV; Escalade EXT; SRX; CTS; CTS Wagon; Camaro; Monte Carlo; Impala; Equinox; Avalanche; Silverado; Suburban; Tahoe; Express; Traverse; Acadia; Sierra; Yukon; Yukon XL; Yukon Denali; Yukon Denali XL; Savana; Terrain; Torrent; G8; H2; OUTLOOK;
    VUE -- Unable to Reprogram BCM
    Reprogram the module with the revised process
    Don't replace the module and program
    Reference Information / Bulletin Number 09-08-47-001A
    2000-2011
    All -- Information on Tire Radial Force Variation (RFV)
    Use the steering wheel shake worksheet
    Don't replace parts or tires without determining the source for a smooth road shake
    Reference Information / Bulletin Number 00-03-10-006F
    2005-2011
    All Vehicles -- TPMS system service and re-learning sensor IDs
    After driving with spare tire, when replacing with regular road tire, clear DIC message and TPM DTC's using scan tool; perform TPM relearn
    Do not perform unnecessary repairs
    Reference Information / Bulletin Number 10-03-16-001
    2009-2011
    All Vehicles --Vehicles on dealer lots for extended periods no start condition
    Refuel with fresh fuel
    Do not replace the ECM
    Reference Information / Bulletin Number 09-06-04-015A
    2010
    G8 -- Sunroof buffeting
    Install new deflector and flocking tape
    Do not replace sunroof module
    Reference Information / Bulletin Number 10-08-67-002A
    2005-2010
    All Vehicles - Intermittent MIL illuminated, DTC P2138 with reduced engine power
    Check wiring and connector
    Do not replace the throttle body or accelerator position sensor
    Reference Information / Bulletin Number 07-06-04-019C
    2008-2009
    G8 - Knock noise from front suspension over small bumps
    Use new P/N 92249538 to obtain all four lower control arms
    Do not obtain all four control arms individually instead of using the new kit
    Reference Information / Bulletin Number 09-03-08-008A
    1998-2010
    All Vehicles -Electrical ground repair - use new replacement fasteners with conductive finish
    Use the procedure and materials in the bulletin
    Do not scrape the paint off the surface and use a star washer
    Reference Information / Bulletin Number 10-08-45-001A
    2010 and Prior
    All Vehicles -Passenger Presence Sensing System concerns with customer upholstery, accessory seat heaters
    Electronic equipment placed on the passenger's seat may cause intermittent issues with the system
    Do not replace the passenger presence system for intermittent interaction with electronic devices
    Reference Information / Bulletin Number 06-08-50-009E
    2008-2009
    G8 - Vibration in steering wheel, moan noise at highway speeds on smooth roads
    Contact the Brand Quality Manager (listed in the bulletin) to obtain a drive shaft
    Do not order a replacement drive shaft through the normal process
    Reference Information / Bulletin Number 10-03-09-001A
    Acadia, AURA, Avalanche, Cobalt, DTS, Enclave, Escalades, G5, G6, G8, H2, Impala, Malibu, OUTLOOK, Sierra, Silverado, SKY, Solstice, Tahoe, Torrent, Traverse, VUE, Yukons - GM Accessory 2-way remote start transmitter battery
    Ensure that the transmitter is not in second vehicle mode and the battery is not dead
    Do not replace the battery if it is less than five months old or replace a transmitter because it is set for the wrong vehicle
    Reference Information / Bulletin Number 09-08-52-004A
    2008-2010
    Allure, Camaro, Equinox, G8, LaCrosse, Terrain - Key cutting procedure for obtaining replacement key
    Obtain the correct key code
    Do not use a four-digit key code
    Reference Information / Bulletin Number 09-00-89-029C
    2008-2009
    Replace the engine mounts, propshaft, balance wheel/tire assemblies or correct the brake rotor runout
    Do not replace the tires before completing the root cause
    2007-2010
    All Vehicles - Refinishing aluminum wheels
    Only cosmetic refinishing of the wheel's coatings, using recommended procedures is allowed
    Do not attempt any repairs that involve welding, bending, straightening or re-machining of the wheel
    Reference Information / Bulletin Number 99-08-51-007D
    2008-2009
    G8 - Shake/vibration in steering wheel, boom/moan noise at highway speeds
    Replace engine mounts, propshaft, balance wheel/tire assemblies or correct brake rotor runout
    Do not replace tires before determining the root cause
    2008-2009
    G8 - Carpet wet when A/C is on
    Inspect the evaporator drain hose rubber grommet
    Do not replace parts until the evaporator drain is inspected
    Reference Information / Bulletin Number 09-01-39-007
    VIP Member MongosG8's Avatar
    Connecticut
    Thanks Paul ..did not realize so many bulletins were out.
    2009 White Hot G8 GT w/ Onyx/Red Int. Sport/Premium, No Sunroof
    Borla Cat Back, VCM OTR Intake, DBA 4000 Slotted rotors and Hawk Ceramic pads, GXP Diffuser painted White, GXP Fascia, Crystal Clear side markers,
    Black Scoops, 20% Tint all around
    20" Camaro SS polished staggered, Shark Fin, Infinity 6032si
    R.I.P. Charlie (Mr GRRRR8)
    R.I.P. Chris (Panzer Leader)
    Senior Member JAFO's Avatar
    Sep 2013
    Newberry, SC
    Thanks for the info Paul!
    Quote Originally Posted by Crazy Paul View Post
    2008 - 2012
    Seriously??? Now there is a piece of good advice. I tried the same with my glasses.... It works !!!, that's gonna save me a whole bunch of money because these eyeglasses ain't cheap!
    --Brian--
    GODSPEED CHARLIE!!! R.I.P.
    Dec 2014
    Lees Summit Missouri
    Hey bro thanks again! where do you get your information?
