Results 1 to 4 of 4
Thread: ac cold on driver side only
    Member whitehot09's Avatar
    Sep 2009
    Sanger, CA
    Default ac cold on driver side only
    My ac has worked fine up untill now.(63k miles) Last weekend blew cold only on drivers side, then next day no cold air at all. Put approx. 10 oz. Of 134a. It blew cold air both sides for a week, then this morning, back to drivers side cold only. Does this in single or dual mode. Obviously trying to diy before I take it in. Any advice welcome. -marc
    09 Whitehot G8Gt
    mods: Superchips 91vararam perf tune, Vararam, hood heat extractor mod , Koni sport yellows shocks/ Strut inserts,SuperPro bearings and strut mounts. SuperPro lca and radius arm, BMR sway bar end links.
    1/4 mile 12.96 using cortex recorder.
    0-60 4.5
    VIP Member BuildItYourSelf's Avatar
    May 2012
    merca!!!
    The system probably leaks
    Or the duct work across the dash to the drivers side may have come loose.
    That's I can think of.
    2008 GT-M. PBM, #885
    Sep 2009
    Sanger, CA
    K yeah most research I've come across with this issue has been caused by a leak
    09 Whitehot G8Gt
    0-60 4.5
    Addicted Member THE Adam V's Avatar
    Jan 2013
    North Canton, Ohio
    Did you discharge and recharge the system? It's sounds like you have a leak somewhere in the system if you are adding that much. Hard to diagnose without a set of manifold gauges.
    2009.1 PSM GT Sport/Premium Package.
    OBX 1 7/8", 3" to 2.5" X-Pipe, SLP Loudmouth, 6k HIDS, VCM OTR
    Rick C Intake and Throttle Body, MM Carbon Fiber Hood, 19x9.5 TSW Nurburgring, Pat G Tuned
