Results 11 to 20 of 42
Thread: Serpentine Belt Installation Help
    Jun 2012
    F*#k me! Fired her up, nasty slapping sound in the motor!!!! No sign of this before belt change, looks like its my turn for a dod delete thread.
    LOLOLOLOLOL
    Your nasty slapping sound is the tensioner whacking against the stop.
    No it should not be at maximum rotation before you even start the engine.
    If you've routed the belt correctly then you need a slightly longer serpentine belt.
    Jun 2012
    Strange, I crossed the part number, and even found forum members using it, but that would explain the install issues also.
    Jun 2012
    I guess I'll pull it off, and try the old belt again. If I just start the car without the belt for a short period of time, would this let me know?
    Stock belt with all stock pullies is 6PK1937 92067442 or 92290768
    Yes you can run it for a minute with no belt to confirm noises.
    Jun 2012
    Bastards gave me the wrong belt. Package was right, belt was wrong. Once you get the correct part its a 30 sec install. No chirps no slap.
    Quote Originally Posted by cstmg8 View Post
    Glad you got it sorted.
    (Always check the contents match the package, especially if the package shows signs of being opened.)
    Jun 2012
    Yeah, seems obvious, but you'd think they'd have a belt right! Showed me!
    Thanks for the help.
  9. #19
    Sep 2009
    Clarksville, IN
    CP does it again. What a resource!
    2009.5 G8GT Stryker Blue
  10. #20
    Jul 2011
    Tucson
    Crazy Paul... thanks for the diagram and tensioner twist info. Just installed both belts this morning... easy !
    My local car-monkeys at Q Pontiac in Tucson replaced my generator and harmonic balancer and therefore had to put both belts back on. AND THEY MADE MISTAKES ON BOTH BELTS !
    I have the double idler A/C belt and they ran the belt ABOVE the upper idler.
    They forgot to tighten the idler on the main belt...so it came loose...the belt slipped off... and shredded. I couldn't believe it !!
    White-hot G8 GXP...1c cam, NicD tune, Kooks mids, xpipe, Solo axback
    TVS 2300 added April 2015
    12.2@116 at Tucson Dragway, DA was 4000 !!
