Results 1 to 5 of 5
Thread: Will the stock Rear lug studs be long enough for a 10mm spacer
    Beyond Help texn884's Avatar
    Helotes, Texas
    Default Will the stock Rear lug studs be long enough for a 10mm spacer
    Hi all,
    After getting the Brembos installed yesterday with is a GRRRR8 mod upgrade the stance of the front wheels and tires look nicer pushed out some.
    If I get the same 10mm spacers for the rears and just use the stock lug studs will they be long enough with the sport wheels?
    Mar 2014
    Moyock, NC
    Anything over 6mm will need longer studs.
    Helotes, Texas
    well crap oh well another project
    Senior Member jpG8GT's Avatar
    Oct 2011
    SW MI
    Nope. Dorman 610-490 is what you need.
    2009.1 Evoke Gray GT prem. sport no roof. CTS-V Brembos front and rear with stock 18s and 19s, Grill mod with custom brake coolers. Custom Tranny cooler, Power steering cooler, 160 Tstat, RotoFab Intake. Pacesetter LTs, Custom Hooker Axlebacks, SSclone tips. HP Tuners and Rick Crawford tuned.
    Base line stock dyno #s 315RWHP 330TQ
    Winter Wait list: Rick C cam and intake. Koni shocks and springs and suspension rebuild.
    Helotes, Texas
    Ok thanks Ill get another 10 and order the spacers this time and tell them i am using the 14mm studs and not the 12mm from Adapter Kings. Its a learning process
