Results 1 to 6 of 6
Thread: Need help with rim sizes
    Senior Member Joeygr8gt's Avatar
    Jan 2012
    Default Need help with rim sizes
    I might be buying a set of 20 X9.5 front rims with a 35 offset. And 20x10.5 with a 45 offset rear. I'm lowered on H and R springs and with a 15 mm spacer in the rear I slightly rub with the 285 tire over bumps. I concern is with the 10.5 rim it's going to be wider than the 285 tire what size tires should I get. Also the front rim only has an inch from the inside of the rim to the strut is that okay
    Sent from my iPhone using Tapatalk
    2009.5 g8 gt
    kooks LT headers, hi flow cats, x pipe, corsa cat back, vararam CAI, ported TB/intake, slp underdrive pulley, billet catch can, qtp cut outs, kaltech tune, camaro 20s,
    350hp...12.60 @ 109.8 mph
    Member missan nissan's Avatar
    Apr 2012
    Orlando Fla.
    roll you fenders...and I bet they will still rub.. from what I have read in the past 10's rub.
    ...Live Fast.....It Won't Last
    The problem is there is not enough offset. Spacing it makes it worse.
    VIP Member BuildItYourSelf's Avatar
    May 2012
    merca!!!
    Even with your spacers off you'll still rub.
    You might get away with a rolling your fenders.
    2008 GT-M. PBM, #885
    Mar 2014
    San Antonio
    And if you roll the fenders on your own using the bat technique, the key is slow slow slow, you can chip the paint.
    Junior Member ModBargains's Avatar
    Feb 2014
    La Habra, CA
    That fitment will almost certainly rub even with a fender roll. In order to fit that 10.5" rear you would need something like a +52 to +55 to give you the clearance in the rear and even then you would need a nice smooth sidewall tire to get it to clear with no issues. I have done a few sets like this and its doable but you need to do the extra work I just finished a set of Forgestars with the proper rear offset and the customer is clearing 295 Michelin PSS with a fender roll.
    http://www.modbargains.com/images/Pr...s-banner-1.jpg
    Elliott Goodman - 714.582.3330 x8009
    Sr. Modification Expert
    Pontiac G8 Parts | VMR Wheels | Forgestar Wheels | Pontiac G8 Exhaust | Pontiac G8 Intake | Eurosport Wheels
    Check out our blog for the latest updates and bargains!
