Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Exhaust clamps
    VIP Member Crazy8's Avatar
    Apr 2010
    North DFW
    Quote Originally Posted by Crazy8 View Post
    I just ordered some borla clamps to try and get a better seal and stronger hold. I keep pulling my connecting pipes off the cats when I go over speed bumps. The borla ones look about 3 times as long as the ones that came with my kooks setup.
    I installed my Borla band clamps last night. Much, much better. They are about 4 or 5 inches wide and have two bolts, one that clamps to each section. It seals much better. I hope it helps hold the dang connecting pipes to the cats when I drag them, but I'm sure I will find out for sure soon.
    09.5 LR G8 GXP A6
    For mods list, honk 3 times.
    You could also just tack weld the pipes on. Sounds to me like you're sitting a bit too low though.
    Apr 2010
    North DFW
    Believe it or not, I'm actually at stock height. Still drags on shit, such as my driveway and these gigantic speed bumps at the local shops.
    I like to swap out cats periodically, such as when I need to pass inspection, so I don't want it welded,
    09.5 LR G8 GXP A6
