Page 1 of 6 123 ... LastLast
Results 1 to 10 of 59
Thread: Fuel Economy
    Senior Member EngineDweller's Avatar
    Mar 2014
    Southeast New Jersey (LBI, Toms River, Atlantic City)
    Default Fuel Economy
    Quick question...gotta drive the G8 to Michigan this week, any tips on fuel economy? How well does the AFM work? I dont wanna bring it, but our other car is a lease and already is too close to the mileage than I want it, so the G8 gets a road trip.
    If you want to get any advantage out of the AFM you cannot exceed the speed limit, have a headwind, or go uphill.
    RCR ported heads - RCR Lunati 219/231 113+1 - LSA Crank - Molnar rods - Racetec pistons
    Kooks 1 7/8 LT - Solo 3" CB - 3.27 diff w WaveTrac MT DRs + M&H FRs on Weld RT-S
    Old 10.09@138.8 1.51 60'
    New ?@? 716 rwhp 652 rwtq
    Apex, NC
    My AFM works up to around 75-78 if the road is flat; the lower the speed, the more it will stay on.
    2009 Hot White G8 GT, CTS-V v1 fronts, Camaro 20's, BMR Sways, Eibach Springs, Rear Cradle bushings. GXP FE3's, BMR rear susp. Kooks 1 7/8 LT headers, RCR custom 3 exhaust, ported LSA blower, 2.38 pulley; Ported heads and TB; LS7 MAF, Racetec pistons, Scat rods, CTS-V crank; FAST 85 injectors; RCR Lunati cam: 223/238 .615/.601, 116 +2 LSA. CTS-V pump/VaporWorx cntlr. Built trans, Methanol injection. Rick Crawford built and tuned. Best 1/4 9.68 @142, 1.42 60'.
    Yeah, my AFM worked well at 73 MPH which is usually where I lock the cruise at. Sure, inclines would switch it off, but it took one HELL of a headwind to do it. I live in the plains and while not the flatest part of the plains, there aren't any mountain grades.
    OP, make sure tire pressure is up to par and your air filter is clean and that's about all you can do short of tuning it for better MPG.
    Chris
    LOL
    Don't ask cammed and supercharged guys questions about fuel economy. They have no clue. LOL
    Start the car in engineering mode. Hold down left scroll wheel and start. Use the scroll wheel to find all active. When engine is in AFM it will change to half active. This is very helpful if you have stock exhaust. After market you can hear the tone change when it goes into AFM.
    After 10 minutes in AFM it will kick out for 1 minute. You can defeat this. Kick it out before the 10 minutes and the timer will start again. It takes effort, but you need to feel the throttle to keep it in AFM. Cruise control hurts for the most part. Slight incline cruise will kick you out, but if you can feel the throttle you can stay in AFM.
    Down hill you can keep AFM active to almost 80. Use that to have some speed going up any hills. Slowly back off the gas as you go uphill.
    Under more construction.
  6. Thanks pir4te thanked for this post
    Likes EngineDweller liked this post
  7. #6
    Beyond Help tchr49's Avatar
    michigan
    Fuel economy??
    I thought that was how much the bastards jack it up from one week to the next.
  8. Likes texn884, EngineDweller liked this post
  9. #7
    Mar 2014
    Hahaha guys Im right there with you...this car was not bought with the intention of saving gas. I just dont have a choice, family emergency and my gas mileage car is a lease. Eventually ill be modding it! Thanks for the input though, it is greatly appreciated
  10. #8
    Senior Member Frostopsy's Avatar
    My H/C/I LS3 can get between 25-30 highway. The secret is to find the car's power band and put it in cruise control. Usually it's around 70 mph. Cruise control is the key though. Our only problem is the small gas tank.
  11. #9
    Moderator LDM's Avatar
    Mar 2010
    Cape Cod, MA
    I got 24.4 MPG on the trip to and from the dyno in CT. That included the dyno pull.
    Len
  12. #10
    VIP Member HVYCHVY's Avatar
    Nov 2010
    Tulsa, OK
    I was getting about 26 running 85 according to the DIC. You can air up the tires to 50 psi and get less rolling resistance.
    2008 MGM G8 GT Mods: Cam, Heads, Maggie 1900, Kooks, Corsa,BAP, Homelink, Auto Dim Mirror, Camaro brakes, BC Coilovers, and some fancy wheels w/ 265/40/18 ET Street II. Tuned by Howard at Redline Motorsports. 524hp 454tq on 7.5 lb boost recorded at XP Racing, OKC OK 3/30/14, 11.82 @ 120 at TRP 5/3/14
