Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: PO449- Evaporative Emission (EVAP) Vent Control Circut
  1. #21
    Oct 2009
    SOUTH JERSEY
    Np...for future reference I tried tightening my gas gap. I bought a new Stant gas cap. I installed the purge valve under the hood. None of these worked. The purge valve Selenoid by fuel tank is on order. Due in a few days. I will post part numbers later for all parts I used thus so....it did get rid of one of my codes, the po445, the po449 is still on and irritating me. Also just got a tire sensor code too, when it rains it pours!
  2. #22
    Oct 2009
    SOUTH JERSEY
    Finally got code off. It was the purge valve canister solenoid under rear of car near or on the gas tank. My mechanic did the replacement and wrote up a quick how to replace. I will post after he gives it to me for posting.
  3. #23
    Dec 2014
    Code 449... i recently had this code pop up. After reading all the good info on this site..i tackled the problem my self. I removed the pass rear tire.. found that i had to loosen the 2 cradle bolts enough to get both hands in there to get clamp off hose.. other than that not to bad of a job. Cleared light..it was off for 4 days.. check engine light came back on! So back in i go... test light in hand..no power to plug in.. so upon further checking i found at the connector right by the gas tank a rock must of flew up and hit the orange wire..it had rotted into..had signs of the green death. I cut out the bad spot and spliced it..cleared the code..all good!
  4. Likes -Ray- liked this post
  5. #24
    Quote Originally Posted by 2fast4 View Post
    2fast, that's great info, nice addition!! Thanks!
