I take it you will need a custom cut driveshaft and there isn't currently one on the market that will mate to a 6L90 and G8 rear end...
Hello Greg! Well I'm not sure what will happen till I get it installed. I didn't ask but I am hoping that the TCM with the trans is blank. If not it's a cake walk to change it to a 90E program.
You wouldn't happen to have access to do the changeover on the VIN would you?
Robbie- Owner/Operator RHX Tuning Fundamentals.
Gray Ghost- The abomination. 2007 Chevrolet Silverado CCSB. AiR Research 98mm turbo, Nitrous, LME 427LSX, 1307AWHP street demon. (Still chasing the 1500 mark)
PBM G8- Slow Australian four door, twin turbo build/6L90E trans swap under way.
PB 2011 CTS-V Coupe- Sleepy Caddy, 632WHP motor/906 spray.
Caterpillar 50 Forklift- Duramax swap
So check this shit out! It just got here:
I never realized the shear size of these transmissions. Here it is next to a fully built Ace Racing 4L80E and built transfer case for the "Street Truck" which is a massive setup:
For the tune, my gut is saying you will have an issue running the 6L90 tehcm in your car...... I dont think you will be able to make it talk and work properly without a ton a very creative work on that end of things... I dont think a tech2, hp tuners, or anything will make it easy..... however, one thing that would work would be to swap your 6L80 tehcm and put it in the 6L90.... you should be then be able to program it with EFIlive or Hp tuners to change things accordingly...
I could be very wrong... but my gut is telling me this is the case from various meetings we had years ago with product eng and the controls people... but if you find someone that can find a good way to overwrite or trick it, then you should be all good.... if not, last case scenerio if you need help I can try to figure out a way to compare all the Valbe body differences.... valves, springs, etc... and be able to make it work easy for you,..... I am not a software guy for sure, so I know nothing about this except for the hallway talk... but component specifics and the differences between 6L80 and 6L90 I can figure out rather quickly if you need it... good luck and let us know it goes on the software side of things and if you need any info to help make this work on the mechanical part of things, let me know..
Well that's not the problem anyways as some TCMs don't have VINs in them anyways... the 90 OS is usually not compatible with the different ECM OS that we have, at least I haven't found one yet that works without it complaining about it. Heck it's not even compatible with the 2010 Camaro ECM operating systems that I've found and those are newer yet. Regardless, the 80 OS works just fine with a full flash onto the new 90 TCM (it's the same computer as the 80 anyways) with HPT although I would copy the 90 oncoming/offgoing pressures and volume tables and shift pressure tables for starters and keep the G8 shift timing structures as is and modify to suit your setup. This has worked on countless other cars and swaps that I've done.
19 ZR1 | 16 Viper GT | 09 Z06 | 94 LS1 GT | 16 Denali | 19 CTS
http://m.ls1tech.com/forums/showthread.php?t=1546829 is what I've found. Hmmmm
Interesting thread.... but not being a negative guy... ... I think it will be a bit more interesting to do than a Camaro ZL1 trans into a Camaro SS... due to the similarity of the rest of the car, the ECM, etc...
if you try to take a ZL1 info and use it in the G8 that may not work out so well..... whereas no sweat in a normal camaro ss....
good luck....
