Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 41
Thread: G8 GT front driver side seat trim
  1. #31
    Quote Originally Posted by xycfer View Post
    Dum question time....Ok so which website is the right one to get the new and improved reinforced version that I see up there in the pictures mentioned?
    It shouldn't matter where you buy it from.
    92207874 Left Front Seat. Side Panel.
    Send a message to Greg at Pace Performance and ask him nicely if he'll check the item by eyeball once you order it, and before he ships it out.
    Gregwas@paceperformance.com
  2. #32
    Apr 2011
    CINCINNATI,OHIO
    I weigh 200 lbs,have not have had your problem,however driver side seat wrinkled,replaced by dealer,same old shit,is that really leather?
  3. #33
    VIP Member MongosG8's Avatar
    Connecticut
    Quote Originally Posted by brewski View Post
    Just the middle sections of the seat are leather .. the sides are pleather or Kangaroo skin ..lol
    2009 White Hot G8 GT w/ Onyx/Red Int. Sport/Premium, No Sunroof
    Borla Cat Back, VCM OTR Intake, DBA 4000 Slotted rotors and Hawk Ceramic pads, GXP Diffuser painted White, GXP Fascia, Crystal Clear side markers,
    Black Scoops, 20% Tint all around
    20" Camaro SS polished staggered, Shark Fin, Infinity 6032si
    R.I.P. Charlie (Mr GRRRR8)
    R.I.P. Chris (Panzer Leader)
  4. #34
    Dec 2015
    Angry Driver side plastic crap - what is it called what is the number to order?
    Quote Originally Posted by kevinm0131 View Post
    I have broken 5 or 6, got the call yesterday that my latest is in. The problem is they are trying to support the side bolster on those little plastic pegs. I will be interested to see what version is coming off and going on mine. I shall take a look now that I have been again well educated by our wonderful CP.
    Thanx!
    I am on 4 or 5 myself. Where do we order new?
  5. #35
    Connecticut
    Greg at PacePerformance can order you a kit to fix this issue for 25 bucks..better than spending the 100 bucks for the side piece.
    I purchased the kit and modified it with some longer screws and changed where I put the screws ..worked out fine.
  6. #36
    Junior Member Satch0922's Avatar
    May 2015
    Both front seats broke on mine (only 40K miles). I am usually not a "rig it" kind of guy but here is what i did on both and I have never had another issue.
    Drill a hole through the thick plastic tab that breaks and put a heavy zip-tie through the hole. Then route the tie through the hole on the seat frame. Make sure you use a long Zip-tie so you can pull it from the side or under seat once routed and connected. This allows you to put the zip-tie tight enough so the trim in next to the seat.
    What you get is some flex (because the trim is not solid against the seat frame) but it is close enough as to not look broken. Hope that makes sense. Seems better than replacing them over and over.
    So far, zero issues with this method and they have been repaired this way well over a year.
    Piece to drill through (one side to the other):
  7. Likes MongosG8 liked this post
  8. #37
    Apr 2011
    DFW, TX
    +1 for the zip-tie method
    09 White Hot G8 GT
    Tuned by Rick Crawford
  9. #38
    Member norton13's Avatar
    Jan 2013
    Toronto
    Quote Originally Posted by Satch0922 View Post
    I did that maybe 2 years ago but I used 2 zip ties still going strong. Mine was the passenger seat. MY Gt is not broken yet but it hangs out a bit on the passenger seat will end up doing the same thing ,even thought I bought the plastic trim will wait till it no longer holds.
  10. #39
    Connecticut
    Ok ..well mine shit the bed again with the modification kit.
    I will try the zip ties but I dont think there is any more meat for me to drill through the tabs ..etc.
  11. #40
    Nov 2016
    Thanks for your information
