Results 21 to 30 of 41
Thread: G8 GT front driver side seat trim
  1. #21
    I just ordered this as well....thanks Paul. Is there an upgrade version?
    This site (below) is usually well up to date with part number updates.
    The number is still good, so I'd say it's the latest available.
    http://www.gmpartsgiant.com/parts/gm...-92207874.html
  2. #22
    Friendswood, TX
    or less turkey and cake.
    LOL!! Hilarious! .....
    ARH Long Tubes 1 7/8" / Magnaflow Mid Muffler / Cherry Bomb Vortex Mufflers / Magnuson Supercharger 1.9 / Ported blower base / 2.70" Pulley / LS3 rockers with Trunion upgrade / Trick Flow LS3 cylinder heads / Overdrive "non-cog" pulley system / 8-Rib Pulley system / Innovator West 10% Balancer / DOD Delete / Lunati Lifters / Custom Patrick G Cam Grind / Wiseco Forged Pistons / Injector Dynamics 85lbs / 4" RotoFab Intake Tube / 102mm MAF Tube / 102mm TPIS Throttle Body / LS7 MAF Card / ZL1 Fuel Pump / JMS Fuel Pump Booster / VaporWorx Controller / B&M Tranny Cooler with fan / Circle-D Heavy Duty Rebuild & 265mm triple Disc Billet Converter / Camaro Tranny Pan / Custom Engine & Tranny Tune by Patrick G / Eibach Lowering Springs / BMR Front & Rear Sway Bars & LCA's / Moog Front Control Arms / DBA 4000xs Rotors / Hawks Ceramic Pads / Breyton BE Wheels
  3. #23
    Friendswood, TX
    The piece you have has already been re-designed and strengthened above and beyond the equivalent piece on a Holden.
    PONTIAC G8:
    HOLDEN VE CALAIS:
    How do you take the SOB off? More particularly, the circular back rest adjustment knob.
  4. #24
    VIP Member kevinm0131's Avatar
    Nov 2008
    Oxford ohio
    "How do you take the SOB off? More particularly, the circular back rest adjustment knob."
    If there is no set screw, which I doubt there is, it should either pull straight out or there is a remote possibility that it threads on, but I doubt it. I'm at work or I would walk out in my garage and check it out. I have not taken mine off, but, on other cars they just push in and snap into place, then pull off with a solid tug.
    Kevin
    2009 SRM G8 GXP A6 + Roof
    Go
    Vararam CAI
    VMS "Stealth" Dyno Tune
    VMS HSRK
    GTPprix's hacked Atari gauges
    Doug Thorley LT's
    Show
    PB
    12.986 @ 108.78
  5. #25
  6. #26
    Friendswood, TX
    I hate asking "dorky" questions when the fix is THAT easy! It came right off!!
    Replacement trim -- went right on easily.
    Thanks Paul!!
  7. #27
    Friendswood, TX
    Quote Originally Posted by kevinm0131 View Post
    I used a 2 small screwdrivers. Just applied "a little" pressure to both sides -- and it slide right out.
  8. #28
    VIP Member MongosG8's Avatar
    Connecticut
    Thank you Paul!
    2009 White Hot G8 GT w/ Onyx/Red Int. Sport/Premium, No Sunroof
    Borla Cat Back, VCM OTR Intake, DBA 4000 Slotted rotors and Hawk Ceramic pads, GXP Diffuser painted White, GXP Fascia, Crystal Clear side markers,
    Black Scoops, 20% Tint all around
    20" Camaro SS polished staggered, Shark Fin, Infinity 6032si
    R.I.P. Charlie (Mr GRRRR8)
    R.I.P. Chris (Panzer Leader)
  9. #29
    Jan 2009
    Albuquerque, NM
    Just installed mine--thanks to the instructions and help posted here---THANKS!
  10. #30
    Member xycfer's Avatar
    Mar 2010
    Central Jerzeeee
    Dum question time....Ok so which website is the right one to get the new and improved reinforced version that I see up there in the pictures mentioned?
