Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: 2009 tower brace
    Apr 2011
    CINCINNATI,OHIO
    Default 2009 tower brace
    Need some sources for tower braces "shock tower braces"
    Administrator Chewy's Avatar
    Bettendorf, IA
    BMR, Pedders, and I believe Whiteline.
    Only go with BMR if you have your mind set on having one of these. Your hood blanket will thank you.
    Senior Member scorpion's Avatar
    Jun 2012
    Armpit of America virginia beach
    And if you do go with BMR once it goes in your not gonna want to take it back out. Pain in the balls
    2009 LR G8 GT
    Varraram intake, LS7 maf, SLP underdrive pulley, granatelli 0 ohms resistant 10.5 wires and coil packs, PYPES 1 3/4 tri y long tubes, OBX x pipe no cats, flowmaster 44 with 4" quad tips, camaro 3.45 rear end, BC coilovers, BMR lower control arms, BMR tow rods, BMR trailing arm, BMR subframe connectors, BMR tunnel brace, BMR strut tower brace, BMR front sway bar, BMR rear sway bar, spyder rear tail lights, powder coated black camaro rims
    6.2L engine swap
    Rick Crawford special
    Ported polished and milled heads (11.6:1) with LS9 valvetrain, Rickifast intake, Rickifast throttle body,DOD delete,CTSV racing lifters, 111 lunati cam, 3000 triple disk coan stall
    2011
    yellow ctsv brake upgrade
    Comfortably Numb Monty's Avatar
    Jun 2009
    South Jersey
    They're more for looks they don't do anything with the structure of the vehicle.
    09 G8GT SwitchBlade Silver/Sunroof:
    SSV Z-Series ll Rims, GXP rear diffuser, Chrome G8 gas cap cover, Console sliding leather lid, Holden Engine Covers, Intake cover delete, Auto dimming mirror, Holden VE Onyx Leather Sports Steering Wheel, SLP spoiler
    Roto-Fab CAI, HSRK, MagnaFlow cat backs, Kooks mids w/ HFCs, GXP Brembos w/Drilled Rotors, VMS Stage 2 tuned, Mobil 1
    Best: 60'- 1.954 1/4-12.753 @ 109.42
    Beyond Help Napalm's Avatar
    Mar 2011
    Memphis TN
    Quote Originally Posted by Monty View Post
    not true but believe what you wish.
    I'll admit its not as good as it could be - IE in a perfect world they would be triangulated to the firewall in the middle of the rail. Failing that - they are indeed helpful to the car's rigidity.
    I will say they are really only useful for someone that has upgraded their swaybars - or changed springs and shocks. Conversly it is probably also good for anyone with the sunroof option as their chassis has less torsional rigidity.
    Jun 2009
    South Jersey
    Maybe the one's that go from tower to tower. The BMR brace is connected to the little stud where you put your catch can. There's no support there.
    Addicted Member terryscott621's Avatar
    Nov 2009
    Whiteline sells some quick release clamps for their strut tower brace. This would probably help if you ever need to do any work that requires you to remove the intake manifold.
    http://www.whiteline.com.au/do_segue...=8%2F06-8%2F09
    Terry Scott
    2009 G8 GXP - Sport Red Metallic (#821 of 1829 / #33 of 74 as Optioned)
    Formerly HSV-GTS-300 Crazy Paul's Avatar
    Perth, Australia
    Quote Originally Posted by brewski View Post
    Evilbay "KSB637" just under $200 with free shipping
    Whiteline Strut Tower Braces - KSB637
    FREE Shipping - Authorized Dealer - US-Based Support
    eBay item number:161127467813
    Mar 2011
    Memphis TN
    true I should have said from the options available the whiteline is the best.
