Damn!!! Great thread!!!
Terry Scott
I agree! I am going to go broke with all the suggestions, but at least I will be smiling the entire time.
Here's some info I received this AM from SuperPro in Australia about their front radius rods and lower control arms. Part numbers TRC1000 & TRC1001
I'm looking at buying a full set from BMR, but I needed more info than what both BMR and SuperPro's site could offer. At first I got the canned email back which infuriated me, and when I pressed for more info, a man named Scott Bennett emailed me back with the below information as well as information that they revisited the pricing on the arms and have lowered them to meet market pricing. I've got a PM into Kyle at BMR to see what that means for us. My goal is to buy the arms all ready to go with the poly inserts because I have no-one around here that can do the work.
On the technical side, the ball joints used in both of our arms utilise an encapsulated, heavy duty nylon style design, made to our specifications to ensure maximum durability.
The caster arms have the caster adjustment plates included in the kit to allow for caster adjustment.
The new pricing structure will close the gap significantly over the price of the individual components.
Just a quick note on the warranty status on the Bilstein shocks..
Forget it - no warranty available. One of my rears broke last week and many emails and conversations with Australia and Germany and three drives to BilsteinUS. No luck.
I did find a new shock I plan on attempting to install to replace both rear shocks. It is the offering for the Camaro rear. 24-222976. Lifetime warranty when installed on a Camaro but nothing for our application. But they are only a little over $100 each so quite a bit more affordable. The compression is a little stiffer and rebound a little softer. How they work with my King HD springs will be discovered this weekend when I do the install.
Amazing compilation!!! Thank you!!!
Anyone have a link for rear subframe bushing install diy? I think I'm going to loosen bolts and do them a pair at a time, but want to avoid taking the driveshaft loose, etc. I've seen mention of the Pedders document (it apparently does not require removing the subframe wholly), which, of course, is not available at this point. I've searched but keep coming up empty other than a few tips here and there. Thanks in advance!
here, from BMR
Sport /Premium
FWIW, here is the alignment specs:
Sport /Premium
for those with OEM bushings, here is the timing
Sport /Premium
torque specs
Sport /Premium
So this kit from pace performance doesn't have the latest and greatest Control Arms for the front?
I don't want to have to do this again in a year.
http://paceperformance.com/i-7138834...l-arm-kit.html
