i don't have detailed step-by-step instructions for you but there are a few things that i've learned/noticed that are worth noting and may simplify your life if you choose to go this route since directions were not provided. it's pretty straight forward, but these few notes are provided to make it easier on your brain and optimize install time.
o2 extensions - you only need one for the driver's side. no need to buy 2 unless you like to hoard spare parts. i've wandered whether or not i would need o2 extensions for this setup and did not find a definitive answer, so here it is.
header/manifold gaskets - i compared the cheap 2 peice header gaskets supplied by obx and the OEM gaskets that i pulled off. since the holes on the supplied gaskets are SMALLER than the holes on the OEM gaskets and the obx primaries, it seemed like a no-brainer to use OEM gaskets. i reused my used OEM gaskets and don't have any leaks. you may say or hear it doesnt work or it shouldn't work.. and it may not for you.. but it worked fine for me so far. for some cheap insurance, it would be best to just buy a new OEM gasket instead of rolling the dice on the used ones.
oil dipstick - you will need to remove for install. the dipstick reaches around the old manifold just fine (reach around..hardy har har) but when you go to reinstall the dipstick once header is in place, you will find the dipstick touches one of the primaries. the stock bolt can be started but it felt awkward enough to where i did NOT feel comfortable getting more than a couple of turns on the bolt. the fix: got a metal spacer i had laying around (estimated 1/2 inch) and a longer bolt. i put the spacer up to the new bolt to make sure the length over the spacer did not exceed the length of the OEM bolt.
x pipe - just note one side is longer than the other on the x pipe as well as the last section of pipe that bolts up to the axle back. it only fits one way and it isn't rocket science .. just pay attention.
obx bolt springs - there were springs supplied with the nuts/bolts/washers and i would imagine they are supposed to aid in expansion/contraction with heat cycles. i tried using them but they were long enough to where i couldn't even get the nut started on the bolt.. so i said f it and left them off. no issues thus far.
check engine light didn't come on until about 200 miles after install.
-beau
