Results 1 to 9 of 9
Thread: torque pro smartphone app Questions, my trans temp is 32* ?
    VIP Member MAC the KNIFE's Avatar
    Mar 2013
    TAMPA
    Default torque pro smartphone app Questions, my trans temp is 32* ?
    1st. the torque pro app on my 7" tablet has been awesome! but why is it reading trans temp as a constant 32 degrees? i have a trans temp option in "engineering mode" on the car, but that's always in celsius. so obviously, i've got a sensor. anybody else have the right temp actually showing on the app?
    2nd. the car is completely stock, and my oil pressure drops to 25-30 at warm idle. it's more like 45-50 at cold idle. is 25-30 normal?
    3rd and last. my IAT is consistently 20 degrees (or more) warmer than ambient air. am i drawing warm air from engine bay? or is the IAT sensor getting cooked against a coolant hose? would a rotofab intake fix this issue?
    Thanks for all the Grrrr8 help!
    2009 GT
    rotofab cai, kooks lt's, tune, 3.27 gears, bmr sways, 6/4 pot brembos, hawk hps, button paddle shifters, 275/30/20 square setup. occasionally autocrossed
    PB = 12.783, 3.70 gears, fbo and tune.
    Want better cabin filters at a lower price? Check my thread! 6 for $25!!!!
    http://www.grrrr8.net/showthread.php?t=38105
    Quote Originally Posted by MAC the KNIFE View Post
    I can speak to the iat, yes that sounds right. And it sounds like the trans temp isn't valid, or pulling the wrong pid.
    I don't thing trans temp is available through obd.
    Aug 2010
    Va. Beach
    I have my dashhawk plugged in and it reads the trans temp perfectly and matches the Eng mode once you convert Celsius to Fahrenheit.
    2009 Pontiac G8 GT A6, MGM
    2006 Pontiac GTO M6, BOM
    2008 Pontiac G6 GXP A6, DBM
    2006 Silverado Z71 L33 A4, SRM
    2011 Suzuki GSX-R750 148hp of pure 2 wheel deathness
    G8 GT - 13.56 @ 106.71 (10/29/2010) (bone stock run)
    Z71 - 16.28/15.67 @ 87.53/87.21mph (2WD/4WDL) (7/9/2010) (K&N and Glasspack)
    Thanks for clarifying. I forget stuff.
    Aug 2010
    Va. Beach
    No problem, it'll also read oil temp too.
    Apr 2012
    Torque pro is awesome. I'll have to see what it reads the trans temp at for me, as I've never paid attention before.
    So I've just started using this - thought I'd bump the thread.
    I don't seem to have Outside Air temp or again using the wrong PID. There are 3 apparently. So eventually I'll hit it.
    Trans temp - there are 5. so also eventually I'll hit it.
    Bought the ODBLink MX device. Mostly becasue I didn't want to cheap out and end up damaging something expensive and because it has some support. I also bought their widows software with the GM enhancement pack. Supposed to read ABS and SRS systems as well as trans, and AC on the G8 and anything built before 2014 that's GM. (there's a ford pack but I hear Forscan works amazingly - for free.)
    I used it to monitor oil pressure on a couple trucks and worked like a charm. Well worth it!!
