Page 4 of 4 FirstFirst ... 234
Results 31 to 34 of 34
Thread: Snapped Fitting on Intake! (HELP)
  1. #31
    Thread: How bad did I screw up?
    http://forum.grrrr8.net/showthread.php?t=36157
  2. #32
    Feb 2013
    warren,ohio
    Yea thats it, broke off flush, i think i could use two part (lord fuser epoxy) or just use brass fitting, close one thanks paul again,again and again...... Your awesome
  3. #33
    OK, seeing that this could be an ongoing issue, I've merged a couple of threads, changed the title so it jumps out at you a little more, and made it a sticky. I know if it were me, I'd want to find this thread IMMEDIATELY.
  4. #34
    Feb 2013
    warren,ohio
    Great, everyone i used the brass fitting and it worked great.. Had a extra radiator overflow line with the bend and it worked great. One side has the smaller end and it fit perfectly into sensor side....
