More than most!!!!
Still pulling splinters from my ass on this one...
:Paid for full three in exhaust with tips..... got full three inch with 2.5" muffs and no tips...
:new LSXr 102 intake and they forgot to tighten bolts on between two halfs and it blew apart throwing gas all over engine!!!!! lucky damn car didnt go up in flames!!!! and I had to get towed!!
:Put 4L80E in car that was supposed to be virtually new.... pulled out cause I blew it a month later and it was completely rusty, and per RPM, they said it looked like it sat outside in snow for a yr!!!!! ps... I never drive even in rain!!!
:Setup my trans and trans controller but didnt tie RPM back into controller so it would shift ok on street but on track it would redline and not shift right.... I had to rewire and figure out myself... the way they did it would have never worked!!!
:After I got car back my A/F gage didnt work at all.... still have to figure out that one... replaced sensor but didnt fix it...
:Orifice size on meth system was a mile off per the meth guyy who sold the system, the new shop I worked with.... their choice of nozzles would never get up to proper pressure and didnt work right!!!
:9" rear they put in and I found drivers side axle was completely loose and dripping oil everywhere.... found it loose only due the oil... all bolts on axles joint were not even hand tight!!!!
:They kept my car 1 year!!!!! tore it apart and then worked on other cars!!!! my car say for so long there.... they did as a filler job but charged me full!!!!
:When they put my fuel injector orings on, they had three different size orings... which they leaked!!!! MIENGINEER and a couple other guys from the forum helped me change orings after it again was blowing gas all over engine in the middle of the night on woodward!!!
: Paid $187 for a battery that was stil under warranty and was not warned about this till after I got bill...
: Paid over $90each for 2 V belts that I was not warned about ..... a bit high I would say!!! and it wasnt the racing kind!!! just normal!!
: Paid $750 for used Camaro brembos for the FRONT only and gave them my brakes and they said they would give me a killer deal.... not sure if it were killer for me?
: They lost my Circle D converter... claimed they shipped it and circle d lost it.... but after over 2 months of complaining about it... they mysteriously found it!!!!
Other than these couple items......
I think Matt is a great tuner but for medium big jobs.....hmmmm..... not too sure about!!! He does have a bigger place now and should help, but I think many of these mistakes were completely out of line and could have caused me much loss!!!! Who leaves the bolts loose on an intake?.... fuel rail lists up and injectors pump gas all over hot ass engine!!!!!! not cool!!!
How is that for an experience???
