Page 2 of 12 FirstFirst 1234 ... LastLast
Results 11 to 20 of 115
Thread: Hard heater hoses from Camaro
    Sep 2009
    VT
    I posted as after careful comparison of images from the camaro link to what I see in the G8, I'm skeptical snaking them up near the firewall. I think CP post suggests the engine is placed closer to the firewall in the G8 than Camaro. With the one ebay sale @ $32 to the porch, I'm tempted to pick them up. Still on the fence. I scored a smoking deal on a ATI superdamper and may allocate the funds towards a ARP bolt instead.
    Sport /Premium
    Nope.
    I was looking at the difference in the water pumps.
    Now it looks like although they've jacked the Camaro WP pulley 1.5" further forward than Corvette/G8, they've kept the heater hose connections the same distance from the engine block.
    So forget everything I said about the Camaro hoses potentially being 1.5" too long.
    Corvette/G8 water pump heater hose connections.
    Camaro LS3 water pump heater hose connections.
    Sep 2009
    VT
    thanks for the clarification. Perhaps just my view, images in section 17 and 19 of the camaro5 link seems to show more room vs what I see with the G8.
    Sport /Premium
    Senior Member GRRR8GT's Avatar
    Spruce Grove.AB. Canada
    I ordered a set yesterday. Delivery around Mar. 5. Sometimes stuff takes a little longer crossing the border sometimes not. No stock in Canada on either coast or the few local dealers I called. They told me 3-4 weeks out of the States. Right.
    Just to give you an idea there $176.42 + tax at the dealer. Ordered off ebay delivered USPS for half that. That $32 and change is like a giveaway. The shipping up to here is way more than that. I'm getting "hosed" and its still a deal.
    I'll let you know how they fit shortly after they show up but I cannot see them not fitting. The engine bays are almost identical on the two cars.
    09 GT PBM Base,6K HID's and relay harness, Homelink in visor, sport pedals, GXP rear valance, Pontiac trunk liner
    Infinity's in doors, Kickers on Deck powered by EXILE and 16OHM center spkr, 40' of dynamat, Weathertech floor liners
    20" Rial Porto's with 245R35 front and 275R30 rear Sumutimo HTRIII's and CTS-V Brembo calipers with DBA Rotors and SS lines.
    Pedders GSR struts with OEM height Sport Ryder Springs and SuperPro bushings. DOD deleted.
    Solo HFC's with Mach Balanced w/J pipes and resonators + 3.5" tips, Harrop Enhanced Performance with EPS custom cam
    Tuned by Patrick G. and cooled by B&M
    "Jack"
    winter 2015 mods....TBD
    New DD 2013 Buick Regal GS, Diamond White, IPF Tuned...
    Clayton, NC
    Nice hose kit. A couple close ups that show proximity to the plugs would be good.
    RIP Charlie, The GRRRR8 One
    [SIZE="2"][COLOR="Red"]
    VIP Member Kermit's Avatar
    Va. Beach, VA
    I'm a bit confused here. What is the benefit of doing this?
    2009 G8 GT MGM.
    Sep 2009
    VT
    I could not pass up $32 to the porch. If it's clear they will not fit, I'm sure I can flip on Camaro5. While they will be here Monday, GRRRR8GT will have the first crack at this as I'm having total shoulder joint replacement friday - will be a few weeks before I'm wrenching again.
    Sport /Premium
    Sep 2009
    VT
    While some will say engine heat reduction by removing the hot heater hoses from the intake surface, I suspect the effect is minimal making this a cosmetic change only - personal preference.
    Sport /Premium
  9. #19
    Nov 2011
    Cincinnati,OH
    Looks like the $32 eBay deal is over. I'm curious how this works out as well. I like how they dip down lower to retain access to the plugs. The techafx looks like they occupy some valuable real estate.
    Sent from my SCH-I535 using Tapatalk 2
    Phillip M.
    Engine: Stock Bottom End
    Cam: BTR IV PD
    Drivetrain: 6L80, Sonnax
    High Compression/Boost/E85
  10. #20
    Addicted Member 2lazy4agoodname's Avatar
    Aug 2011
    Staten Island, NY
    Really hoping this works out. The dip down for the plugs is much better on this than on the HHRK.
    16 SSB SS A6
    VCM, KOOKS, 3" Solo, RCR MANI & TB, Eibach, VMR
    09 PBM G8 GT -
    Built By Rick Crawford Racing
    404 Stroker / Ported LSA Blower / 2" Headers / Built Trans / Alky Methanol
    RCR Heads & Cam / TPIS TB / ATI Balancer / Vaporworks & V Pump
    Solo / CTS-V Brembos / BMR / VMR V701 / H&R Coilovers / Holden SSV Conversion
    9.89 @ 138.8
    09 WH GXP M6 (#1827 of 1829)
    Roto-Fab / Solo Mach Shorty
