03-21-2017, 07:19 PM
#221
Vendors
TooManyHobbies
The good news: Had a friend come over and we evacuated the system, vacuumed it down, and filled it. After that made lots of cold water. The tank got as cold as a typical american style lager beer
. Discovered that I am still dripping some coolant though from a fitting. I will need to drain it again and see it I can stop that. It will be hard to fill since I will not have much play in the lines to fill it now that the AC is filled up.
Without teflon tape the temperature changes will cause leaks. I would recommend a bleed fitting in the top of that reservoir if any one were to make another one. Just put a xxxx load of stop leak in it LOL Good to hear you made progress, wiring work out OK?
03-22-2017, 02:48 AM
#222
TrekGTO
It has teflon tape in there. Going to pick up another fitting today in case that one is boogered up. A bleed fitting would be extremely useful. Wiring was easy peasy other than getting another set of wires through the firewall. My AFR gauge wiring and methanol injection wiring already goes through there. 10 pounds of wire in a 5 pound hole, LOL.
03-22-2017, 05:06 AM
#223
Vendors
TooManyHobbies
Oh that’s not good, I hope I didn’t booger the threads on the stainless 45s. It is difficult clocking pipe fittings, getting them tight and facing direction you want. I have pipe taps here to chase threads but they are to expensive, use lots of good tape. Some of the tape you see at Home Depot like places is so thin. Sorry for the PITA.
03-22-2017, 05:32 AM
#224
Millrose 70885 on Amazon... Incredible stuff if you need ptfe tape for anything.
Post Thanks / Like - 1 Thanks, 1 Likes, 0 Dislikes
03-22-2017, 06:27 AM
#225
Vendors
STL_G8GT
That is what I use, I have a life long Plumber friend and shared his shop for 2 yrs. I picked up a lot of tips and tools during that time. The blue stuff is the good shit. I never looked on Amazon, now I'm mad I just ordered hose fittings from Amazon I could not find anywhere else.
03-22-2017, 06:36 AM
#226
Shoot, order it from Dairy Queen ....as long as it works!
03-22-2017, 09:04 AM
#227
Have the Millrose on order from Amazon, but won't get here until tomorrow. I did find a similar product called Megatape at Lowes and will try that tonight.
03-22-2017, 10:40 AM
#228
Vendors
The Millrose is just a heavy duty Teflon tape for professionals.
03-22-2017, 07:00 PM
#229
03-22-2017, 07:37 PM
#230
Vendors
TooManyHobbies
OK, I think the Megatape did the trick. So far so good anyway. I will check for drips in the morning but so far nothing. The picture is the temperature of my water tank after running a few minutes. After I shut off the engine the supercharger case was cool to the touch the rest of the engine obviously was not
If the leaks are still gone in the morning I will put the nose back on it in the morning and head for Valdosta on Friday.
Daymn Son you did good! I guarantee you will have the coldest bumper there! People will be sitting on your bumper just to cool there ass. You have HPT to data log at the track?
You know what all that cold heavy aluminum is like a heat sink the aluminum will help to carry the heat load also.
