Page 1 of 6 123 ... LastLast
Results 1 to 10 of 56
Thread: Rear End Clunk - Driveline
    VIP Member Rawyzf's Avatar
    Blaine, MN
    Default Rear End Clunk - Driveline
    If I am rolling and holding a gear, low RPM, and blip the gas and let of, I can hear and feel a clunk while catching and engaging power and the clunk when letting off.
    Sounds like a bowling ball rolling around in the spare wheel well
    Any idea where to start with this?
    I don't think its transmission, I had the fluid level checked and it was good.
    It feels like something is loose in the driveline/driveshaft in my opinion. Feels sloppy.
    [COLOR="#000000"]
    [B][COLOR="#000000"]
    Super Stock! I12XLR8's Avatar
    Jan 2011
    ON, CAN
    Very strange. I just noticed the same thing a few days ago but mine is more intermittent. It seems to only happen if I brake hard right after an up shift, but not every time.
    I assumed it was something loose in the trunk but emptied the trunk last night and was able to make the noise this morning. I am very interested in opinions on this.
    I have the GXP rear if that changes anything.
    Blaine, MN
    That is how mine started, didn't do it all the time. It's getting pretty bad now, as to where I need to bring it in. It does cluck more often when downshifting coming to a stop too, upshifts at high rpm are not an issue.
    I have the Camaro 3.45 Differential.
    [COLOR="#000000"]
    VIP Member vert's Avatar
    Nov 2008
    Indiana
    In older cars it usually was a sign that a u joint was going out, so I would think I would start with the driveshaft. Might check the rubber couplers and give the shaft a turn with your hand to see if it has any play. Driveshaft that is. LOL
    Blaine, MN
    Quote Originally Posted by vert View Post
    Thanks Vert.
    U-Joint, have any pics of what/where that is. I recall trying to spin the driveshaft a few months ago and it had no play. Also, rubber couplers, let me know what you mean by those. I'm a visual person, lol.
    [COLOR="#000000"]
    Blaine, MN
    Found this thread, so I can visualize.
    Are the U joints the ends of the driveshaft, shaped like a U? ()
    http://forum.grrrr8.net/showthread.p...hlight=u-joint
    [COLOR="#000000"]
    Blaine, MN
    Found this thread too, sounds like the last 3 posts are exactly what is wrong. Now I need to know what thier cure was.
    [COLOR="#000000"]
    Nov 2008
    Indiana
    Not sure if you saw this from CP, parts diagram
    http://forum.grrrr8.net/showthread.php?t=14220
    Blaine, MN
    Yup, thanks!
    I just printed this out and plan to check bolt tq specs on mine. I am not sure how to tell if the UJoint is bad, but I'll crawl around and take a peek
    [COLOR="#000000"]
    Blaine, MN
    Ok, just crawled under the car. I can turn the driveshaft a tiny bit and it clanks as I go back and forth. Bolts seem tight though.
    [COLOR="#000000"]
