Replacing a wheel hub stud?
Anyone know if it's true, when replacing a broken rear wheel stud on our cars, the hub assembly must be taken apart, and a new wheel bearing installed in order to do this repair?
Discount tire broke a stud, and sent me to Meineke to have a new one pressed in. Meineke claims the above procedure must be done to replace the stud. Thery're claiming at least 3 hours labor plus over $300 for the wheel bearing and another $100.00 or so for a new hub assembly. I found the parts at GMPARTSCENTER.net for $213.00 and no shipping charges.
Reason: spelling
Bob N
2009 G8 GT
Panther Black
Black w/Red Int.
Formerly HSV-GTS-300
You've already been told on the other bored that the new wheel bearing requirement is a load of horseshit.
Need proof?
Remove & Replace Rear Brake Rotor:
http://www.grrrr8.net/crazypaul/rbr.pdf
Remove & Replace a Rear Wheel Stud:
Please note, removing the knuckle from the vehicle or removing the hub from the knuckle is not required here.
[You are not disturbing the relationship between items 4&2 with item1 knuckle]
http://www.grrrr8.net/crazypaul/rearwheelstud.pdf
Replacing the rear wheel bearing is required if you press the hub from the knuckle.....this would only be done if the knuckle was removed first from the vehicle.
[If you press item4 from item1 then you must replace the bearing item2.
http://www.grrrr8.net/crazypaul/rearhubbearing.pdf
Nothing like having an expert available when I really need one.
Thanks so much Crazy Paul!
I think I can handle it myself, thanks to your excellent service manual info.
I'm convinced the guy at Meineke didn't see the instructions for "stud" removal.
Bob N
2009 G8 GT
Panther Black
Black w/Red Int.
Im a little confused on this one. Can the stud be removed from the hub assembly without removing the hub from the knuckle? Is there enough room and can a 610-490 stud have enough clearance to slide back in?
Sent from my iPhone using Tapatalk
1970 SS454 Monte Carlo - triple black
1970 Convertible Mont Carlo
1970 K10 short wheel base
1971 SS454 Monte Carlo - Red with black gut & top
2009 Silverado 1500
2013 9C1 - black
Mine was the passenger side rear. Looking at it from the inside,( under the car) at just about the 3:00 position there is a space about 2 - 2 1/2 inches
with enough room to clear everything. You will have to remove the caliper mounting bracket, and the rotor. Cut-off the existing broken stud as close as possible to the hub. Then hammer or drive it out. Drill a small pilot hole from the outside, using the stud hole to guide the drill bit, through the dust shield. Then from the inside drill a larger hole thru the dust shield to clear the new stud. Draw up the new stud with a lug bolt using some washers to take up space on the stud.
I imagine the other side (drivers side) should have the same space available, hopefully in the same area.
Bob N
2009 G8 GT
Panther Black
Black w/Red Int.
Thanks for the info. I'm actually considering longer wheel studs to accommodate aftermarket wheels. If I end up having to put new studs in ill use that method.
2009 Silverado 1500
2013 9C1 - black
