Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: Baer brakes fitting 6 piston calipers as we speak to G8
  1. #21
    Administrator Steve's Avatar
    Olympia,WA
    Anyhoo- to get this back on track.
    Any chance in hell of these babies fitting on the 18" stock wheels?
    My Long term goal is to run 20's in the summer but keep my stock 18's for winter driving so that's why
    -= R.I.P Charlie =-
    http://g8gt.blogspot.com
  2. #22
    SF Bay Area
    Quote Originally Posted by Steve View Post
    I believe they will fit the 19s. Not sure about the 18s
    mike
    dms
  3. #23
    SF Bay Area
    I thonk the prices will be in the $1895 per axle. that is seriously lower than the offshore unit that is available.
    If you are going to road race, do not get the rotors drilled. just slotted and plated
    mike
    dms
  4. #24
    Olympia,WA
    I noticed you mentioned that before - why is drilled worse? less braking surface? Any pics of said system yet on mike's g8?
    -= R.I.P Charlie =-
  5. #25
    SF Bay Area
    The only time I think that drilled rotors are OK is if they are actually cast into the rotors. Drilling them, can concentrate the heat so much, that under the realllllly severe usage such as a 25-30 lap roadrace run, can heat the rotors up so fast, that the venting cannot eliminate the heat fast enough,a dn service cracking can concentrate at the drilled holes.
    Now the vehicles yo see road racing with drilled rotors, were actually had the holes cast in them when made
    mike
    dms
  6. #26
    Olympia,WA
    Will you be selling these break kits directly? or through pedder dealers, or where can we get these babies when they're done
    -= R.I.P Charlie =-
  7. #27
    SF Bay Area
    Quote Originally Posted by steve View Post
    will you be selling these break kits directly? Or through pedder dealers, or where can we get these babies when they're done
    some of our dealers will be selling them. We will be testing them o the 2 pedders g8s
    mike
    dms
  8. #28
    Olympia,WA
    Any updates on this?
    -= R.I.P Charlie =-
  9. #29
    SF Bay Area
    I believe the axle set will be 1895. I think Mike Haddad is picking up his G8 tomorrow. So I think they are done.
    I just did some checking. As far as I can tell the brake stuff is all done. BAER is doing testing and they ae a few days behind. So they are not ready yet. Sorry
    mike
    dms
