Looks like another great day at the track, Doug, losing a tire must have been interesting.
How was the bike ride? I assume you stayed on this time!
RIP Charlie, The GRRRR8 One
[SIZE="2"][COLOR="Red"]
Thanks Zodiac; it stays nice and flat in the turns now for sure. Brian, the Assault on Mt. Mitchell went well; stayed on the bike and finished with a personal best of 7 hours 41 minutes.
Good run at the track. Looks like the car is doing great! Will be even better when you can ditch the extra 200lbs and run solo.
Thanks Rick; I may get to solo next time out. Better tires will help tremendously as well. Since I blew one of the RE-01's I've got to get another set anyway so I'm planning on a set of Toyo Proxes R888's slightly used and shaved to 3/32's. They should be pretty sticky.
