Results 1 to 7 of 7
Thread: Cooling system operating pressure
    Junior Member Grumpy6L's Avatar
    Karratha, Australia
    Default Cooling system operating pressure
    Does anybody know the cooling system operating pressure
    I am wanting to pressure test my 6.0L after it got a bit hot the other day, want to make sure I haven't cooked anything other than the overflow resevoir.
    Cheers
    HOLDEN VE SSV
    Custom cam, Full Stainless Custom exhaust, ORSM OTR CAI,
    Monster Clutch, Rip Shifter, SSL springs,
    20" Verde Kaos
    422rwhp
    Cooling System Leak Test is done to maximum of 130kPa.
    130 kilopascal = 18.8 pound/square inch
    Normal operating pressure will be lower than that, maybe something is written on your radiator cap.
    VIP Member american_kestrel's Avatar
    Virginia
    GM SI Database says the radiator cap is rated at 15 psi when it starts relieving excess pressure. But testing procedures for the cap say to pressurize the cap (removed from radiator) 17-22 psi to test it works. I'd say between 15-22 psi.
    Virginia
    I missed CrazyPaul's post while I was looking it up. What he said considering what I found in GM (SI) Service Info.
    Karratha, Australia
    Yeah roger that, was reading the service manual it says max press 130kpa
    Then low an behold the rad cap says 120kpa, might test it at that eh!
    Cheers mate
    HOLDEN VE SSV
    20" Verde Kaos
    422rwhp
    Quote Originally Posted by american_kestrel View Post
    Ummm NO.
    Max cooling system operating pressure will be 15psi.
    Max test pressure of the entire cooling system in the car will be 18.8psi.
    (Going to 22 psi to test the function of the cap relief [when isolated from the car] does not mean the entire cooling system can handle anything more than 18.8psi).
    Karratha, Australia
    Tested at 120kpa (17.4psi) all seems good, bit of a ghost in the machine I think.
    Tad worrying as thermos didnt work the other day, checked all relays and fuses, tested thermo fan motors - nothing?
    Replaced thermostat today, ran it up, then gave it a bit of a flogging, fingers crossed.
    If anyone has come across something similar to this please let me know, if it hadn't of been sitting in the drive way at home when it got hot might have been a different outcome.
    Thanks for ya help peoples.
    HOLDEN VE SSV
    20" Verde Kaos
    422rwhp
