Mine showed up, put it on the tester and even with being shelf ridden for 3 months still tested 93% against a load without being refreshed. 2amp for an hour bled surface charge and 12.67 with no post/clamp drop. And 918 cca. Not bad
Ron
"As soon as you're born you start dying, so you might as well have a good time" ~ cake
2009 G8 GT - LSA >TT
Exact same thing happened to me. Battery showed up at the shop where my car was being worked on and it was completely jacked up. Much worse than yours. I could see the glass mats through a 2" hole. I called and they refunded my money and let me keep the battery. I gave it to the guy doing the work on my car and he patched it up and used it for his boat.
Panther Black Metallic
577rwhp / 547rwtq
Magna Charger TVS MP1900
Custom Blower Cam
DOD Delete
2.8 Pulley
PowerBond 10% Overdrive Crank Pulley
ZL1 Fuel Pump Kit
JMS BAP
FAST 65lb Injectors
Roto-Fab CAI
American Racing Longtube Headers
GXP Axlebacks
Camaro 3.27 Differential
CTS-V 19x9/19x9.5 Wheels
Bridgestone Potenza S-04 Tires - 255/40 - 285/35
How are your ACdelco AGM batteries holding up after a couple years?
09.1 G8 GT, 20x9/10 Red G wheels, magnaflow catback, DT's, Crawford ported TB/manifold, Spectre 4"/LS7 MAF, Rotofab, HID's, Aussie SV6 tails, GXP rear diffuser, BMR strut bushings/cradle inserts, BMR sway, Megan Coils, CTS-V 6/4pot Brembos, HSV steering wheel.
http://i92.photobucket.com/albums/l4...psce2f18b1.jpg
My initial car battery was not AGM - as best as I knew
it was however sealed and it lasted some 4 years in the car - or maybe a tick more. my new battery is AGM per it's sticker and it's gone almost 3 so far.
I put in some new fangled Exide AGM I bought off of Amazon and it's been great! Seeing that my car sits more than is driven, I guess that's good!
I do keep mine on a Deltran Battery Tender 365 days a year though.
I went with the Exide due to its higher than OE CCA.
Try advance auto and use a code. You can 30% off
