Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: Fog light relay?
  1. #21
    Member Phuton19's Avatar
    Mar 2012
    N. Houston
    So, after trying the relay, still nothing, new fog light bulbs, nothing. What else could it be? the switch itself or wiring issue from the lights? I may drop by a gm place and have them look at it just to give me an idea.
  2. #22
    I had a similar issue. My fog lights worked and then stopped working at one point.
    I performed the relay and fuse swap diagnosis to no avail. I also swapped out the side market bulbs (in the side of the bumper, not the headlamp assembly) and fog bulbs. Still no fix. The be clear, the fog light switch, once pulled out in the dash, still works as the fogs lights are indicated as being on on the cluster.
    I got help by reading GOPHERIT's post on the other board as it relates to connector X108. This connector is located on the passenger side below the passenger side headlamp housing on a G8. It turns out that the plug was loose and since it's fighting gravity, dealing with going over bumps and whatnot, it got loose. I cannot seem to see if the connector has a TPA (Terminal Position Assurance) connected to it. Or even if it has a provision for one.
    #21 in the following image:
    http://ls1tech.com/forums/conversion...l#post18669271
    2009 LR G8 GXP - M6, Roof, Onyx/Red Interior
  3. #23
    Quote Originally Posted by GXP25 View Post
    Did you need to remove the headlight housing to access the plug?
  4. #24
    merca!!!
    You can get to the plug from the inner fender, wing tray or pop the passenger fog bezel.
    You have to remove the bumper cover to remove the headlights BTW.
    Actually on a gt front you may get to it best from the lower grill bezel if it one piece. I'm not got on the gt.
    I would do the inner fender. Probably easiest and it's most likely the problem. Grease it up.
    2008 GT-M. PBM, #885
  5. #25
    I checked that harness and it was in place and not dangling. I removed it and reconnected and still no fog lights.
    So far I've checked the fuse, the bulb filament looks intact and the dash fog indicator comes on.
  6. #26
    EDIT:
    I rechecked the harness behind the bumper and it was loose. The tiny retaining notch tab was worn off so I used a zip tie to secure the harness. All good now. Thanks!
  7. Likes STL_G8GT liked this post
