Page 3 of 11 FirstFirst 12345 ... LastLast
Results 21 to 30 of 110
Thread: Oil Cooler (tons of info enclosed)
  1. #21
    Sep 2010
    South Africa
    Your car has the 6.0 L98 engine which has no AFM hardware installed. From factory the L98 had a stock volume oil pump.
    The 6.0 AFM engines (L76 & L77) have higher volume oil pumps fitted.
    Melling 10295 is stock volume with a 10% pressure increase = higher pressure oil pump.
    Melling 10296 is a higher volume pump....it pumps something like 15 to 18% more volume.
    It comes with 2 springs. If the blue spring is fitted it will output normal pressure. Fit the red spring and it will output higher pressure.
    10296 with a red spring will give you higher volume & higher pressure than a stock pump.
    Thanks for the info CP.
    I will get the 10296 pump then.
    2008 Chevrolet Lumina SS - Silver. Roto-Fab CAI. Custom exhaust and Brospeed headers.
    Livernois Stage 2c cam with FAST 102 intake. Powerbond UDP.
    BMR Sub-Frame Connectors. Spohn LCA's. Pedders Supercar Coilovers.
    493 Hp
    12.9 (Road tires, unprepared track)
  2. #22
    OCD DIYer Eidolon's Avatar
    Raleigh, NC
    Would you guys recommend a higher volume or pressure oil pump if a cooler is installed?
  3. #23
    Addicted Member iisme13's Avatar
    bedford tx
    Cp. how much is the harrop oil cooler?
    09 VE SS-V
    Performance:
    404ci Lunati Crank and Rods, Wiseco Pistons,TSP 235/239,Dallas performance LSA Heads, Yank 3600SS Stall Built Trans
    Appearance: SS-V conversion/ Brembo's/ XXR 522's/tein springs/ HSV gauges
    Old Numbers 378hp/365tq
    New numbers 5xxrwhp\5xxrwtq
  4. #24
    Quote Originally Posted by Eidolon View Post
    If you have AFM hardware you'll want higher (than stock LS) volume as per what L76 had from factory.
    If you have no thermostatic valve installed between engine block and oil cooler then on initial startup you'll be begging for greater flow, due to the added oil volume of hoses and cooler.
    IMO there's no point fitting a higher pressure oil pump if you are going to be leaving the stock AFM oil pressure relief valve intact inside the oilpan.
  5. #25
    bedford tx
    Cp. so would you say when I do my cam swap to take out the valve? Or no. Any idea on the harrop kit.
    09 VE SS-V
    Performance:
  6. #26
    Quote Originally Posted by iisme13 View Post
    You'd need to remove the oilpan. I still don't know the thread on the oilpan relief valve to source a suitable plug. Oilpan relief is just something unseen and not needed if you have no AFM hardware, I'd go out of my way to bin it.
    Go to the Harrop website, shop online section.
    Fill in your details and get a price shipped.
    http://www.harrop.com.au/products.php?cat=33
  7. #27
    Sep 2010
    South Africa
    The Melling 10296 High Volume pump is slightly bigger than the stock pump. It is thicker. I assume it is still a bolt in part. I will not need to modify anything to fit this pump.
    493 Hp
  8. #28
    Sep 2010
    South Africa
    Has anybody here fitted the Melling high volume pump, 10296. Does it just bolt straight in?
    493 Hp
  9. #29
    Boardman, Ohio
    Just an update.
    The Caprice PPV cooler will work with stock G8 exhaust manifolds but not with the ARH long tubes.
  10. #30
    Just an update.
    Very cool!
