Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: reprogramming key and fob
    Friendswood, TX
    Quote Originally Posted by TomPierce View Post
    Owners Manual Page 2-13
    1. Turn the ignition to ON/RUN with the new section (A). The vehicle must be in PARK (P).
    2. Select Remote Key from the personalization menu.
    3. Select Program.
    4. Press [Lock] and [Unlockl] on the new section (B), at the same time, until you hear two beeps.
    5. Repeat Step 4 for all other keys, including keys that require programming or ones previously programmed to the vehicle. Any key not reprogrammed will be erased.
    6. Turn the ignition to LOCK/OFF.
    7. Join sections (A) and (B) until they click. Do not join the two key sections until programming is complete.
    Here is a "dumbass" question -- why am I not getting a "personalization menu" from engineering mode?
    Moderator LDM's Avatar
    Mar 2010
    Cape Cod, MA
    Because you don't need to go into engineering mode to reprogram the key fob. It's one of the main screens you cycle through. I think it says "Customize Options" if I remember correctly.
    Len
