My 09 GT will warp its front rotors after about 10k miles. Have tried OEM and DBA 4000 slotted with the same results. This is becoming a pain to swap my rotors out ever 10k miles.
I have done the searches on upgrading the front Brakes. Looks like SS Camaro or CTS-V are the cheaper way to go. Or just straight Brembo if you have 3k in spare cash. With the SS Camaro or CTS-V you need to swap your rims or add spacers (spacers are not really an option in my mind). Ultimately I would like to keep my rims (and not spend 3k) - so that rules out these upgrades.
Most folks say to stay away from drilled rotors. Lots of issues with cracks and premature pad wear. However I am debating the cooling effect drilled will have over non-drilled. My guess why the G8 warp's rotors so quickly, is they do not have adequate cooling.
Anyone running drilled and slotted on their fronts? If so, what kind of long term performance have you seen? Cracking? Pad wear?
