Looks grrrr8! I've had the complete rear set sitting around waiting for this damn heat to cool off a bit before I do the swap.
Tim
2009 PSM GT Fully Loaded
GM Sirius Connect SIRGM2L - INSTALLED (No more XM!!!)
Fasterproms Ported Intake Manifold w/LS3 TB
Camaro Brembo Brakes @ all 4 corners
Complete GXP Suspension Swap
GXP Axle-Back Exhaust w/x-pipe
Hacked Atari 3 Gauge Display
Superchips Cortex Tuned
Vararam Ram Air Intake
OEM Bluetooth Add-on
BMR Front Swaybar
HSV Valve Covers
20" Camaro Rims
Vector HSRK
6k HID's
need info on install /do you need rear brackets and rear shoes ???
Yes to both questions. I just installed mine yesterday and it's pretty straight forward. The rear brackets and custom made e-brake shoes were purchased through Greg at Wasslow.com. Contact Greg to see if he has them in stock still. The e-brake shoe can be removed and installed without removing the axle (the manual says so, but we now know otherwise). Also the rear Brembo calipers are roughly $64 new, and you can get the rear rotors from slp on ebay for $60 shipped with less than 100 miles on them. Hope that helps some.
Tim
BMR Front Swaybar
HSV Valve Covers
20" Camaro Rims
Vector HSRK
6k HID's
Yes.
+1 on his info.
You need the following, and Greg's site will be the source for all of this where possible.
- Custom G8 parking brake shoes (allows use of Camaro rotors; out of stock as of this posting, but Greg has more on order)
- G8 rear Brembo Brake adapter kit (correctly positions Brembo rear caliper; includes bolts needed for caliper and bracket)
- Right and left rear Camaro Brake calipers. You can have them powdercoated any color, or you can PM Greg and ask for the last-gen CTS-V calipers instead, which come silver and have a black "V" on them.
- Pin kit. The other users/Greg can correct me if this is not needed as extra, but this should be the pins and springs to bridge the caliper window and hold the pads in place.
- Camaro Rotor and Pads. Greg can provide these as well, or you can purchase them elsewhere. For my part, I'll purchase DBA rotors and Hawk HPS pads to match my front wheels (Hey, another vendor!).
Hope this helps!
Looks good!!! What wheels you running?
sorry guys being super busy at work this past week i will take more pic soon need to get my camera out the garage im running ruff racing r943 8.5 x 20f /10 x 20r with nitto nt555.
