When using our rear lower control arms you will need to use adjustable toe rods to get the geometry back in spec as far as the toe goes, but we have seen no ill effects as far as being unstable under hard braking or any binding and I am sure that is due to the arc the arm moves on. We have quite a few of these rear lower control arms on late model Camaros that are being raced heavily and have had nothing but rave reviews on them.
T.C. Davis
BMR G8/5th Gen Camaro Classic GM Tech/Sales
tc@bmrsuspension.com
www.bmrsuspension.com
813.986.9302
Like us on Facebook!
ok cool. just one more question i already have the bmr toe arm but its not the adjustable unit. but i do have the pedders bolts that give more adjustment. will this be enough to correct for the arm?
im looking to run 1.5 neg camber anyways.
Great questions hayabusa160, so......what's the word on this? So I take it this is more of a drag racing part, then a road racing part, because we love neg. camber, but by making it shorter, drag racers will like it more with no camber.
As far as pure handling goes you would want negative camber but that negative cambers comes at the price of additional tire wear, now this is perfectly fine if you are driving a race car but most guys on here aren't willing to give up too much tire wear for a little bit of extra handling. I hate to specifically say it is for one form of driving or the other because it could really work in both instances depending on the vehicle and what kind of driving is done with the vehicle.
T.C. Davis
813.986.9302
We kind of knew they would be fine for racing. Anyone setting up for track use is going to be lowered for better handling. BMR is not going to make a part that is weaker than stock. The concern is the adjustable arm for the stock height vehicles. The more points of adjustment, the more problems. Do you eliminate the cam bolts with the adjustable arm. If they are going to make two arms, make 2 specific lenghts.
I am trying to get the higher ups to do stock length fixed non-adjustable lower control arm for ease but I am not sure how well that will go over with them. In all reality you could get rid of the cam bolts if you were going to use our rear adjustable lower control arm. There is going to be enough adjustment in the adjuster on the rear arm that there will be no need for the cam bolts if you choose not to use them. I am going to try to either get them to sell a bolt kit or include it with the arm that will come with piece to lock the arm in place so you can get rid of the cam bolts.
T.C. Davis
813.986.9302
