It produces less understeer. Pete from Pedders recommends this setting for the Pedders bars. Pedders has more front adjustability, but after trying all the different settings, I absolutely find this the best setting. Going full hard will definitely keep you more upright, but it also produces a boat load of understeer. You will find the most control with this setting.
I'm running front soft, and rear medium. My car feels very balanced, no under steer, and the rear doesn't want to kick out when cornering hard with throttle.
If you want to get the tail out easier, set the rear to hard.
That seems like an awful lot of bias toward the rear... I'd think that'd result in more oversteer if you get on the throttle through a turn or especially if you hit a bump mid-corner.
I've got my BMR sway bars set as high as they'll go front and rear and I LOVE the way it feels. Nice and tight and flat. It does result in a slightly bumpier ride, but for some reason I even enjoy that. Maybe I'm just weird. But it handles beautifully.
Yeah, it was necessary, unfortunately. I've got the same sway bars you do, the BMR's, and I still used their instructions. Everything I posted here is additional recommendations on top of their instructions. So I had to get a tie rod end puller ($12-$15) from my local auto parts store. Trying to install the bars without taking off the tie rod end would be rough because you have to rotate the bar and the tie rod end will get in the way. I believe I ended up undoing it on both sides. So long as you don't touch the lock nuts, you won't need an alignment.
I always hate fiddling with tie-rods unless I'm changing them - seems like I'm always tearing boots. Did you have any issues when you pulled them?
Um... Well, I tore a boot.
The puller got the tie rod end bolts out of the knuckle without issue. But later in the install I managed to catch the boot on the passenger side on one of the bolts for one of the lower control arms. Turned the wheel to get clearance without knowing it was caught and riiiip. So uh... be careful!
the tie rod boot rips really easy lol.
i had to replace mine installing the sway bar it somehow got pushed up against the dust shield when i was twisting the sway bar in and sliced it open.
